Hey guys, Im stripping lots of crap off my cef, so anyone that wants something just ask.
Have most interior bits from hoodling to carpet, minus rear seats. Have electric window switches (not master), climate control unit (broken a/c button), foot hanbrake assembly, auto brake pedal box etc etc.
Have full a/c system minus compressor.
Will shortly have full HICAS minus power steer pump, inc lines etc.
Also have engine mounts suit RB25det in good nick.
May have other stuff just ask.
Most stuff is free, some worthwhile items will be cheap, or if you have either a LH side mirror or a RHR quarter window Id be happy to swap a number of things for these.
Cheers
https://www.sau.com.au/forums/topic/244246-a31-cefiro-parts-for-salefreeswap/
the cover for the vent on the passenger side? mine wasnt there when i bought the car..
also need the ... cover for the thing to the right of the steering wheel, from what looks like the mirror adjustor is supposed to sit on
right hand side thin
Yep got a couple of sunvisors in black, dont have the passenger side vent cover sorry, but do have the thing that the mirror adjuster goes in.
Should also state that these parts are on the Gold Coast.
Plastic shroud around the air con controls.. wont stay on as the clips are broken. Also the shroud that covers the stereo. Mine has a crack in it. :rofl:
Thanks.. Adam.
  • 5 weeks later...
Classic post...welcome to the other 100 or so Cefiro owners without this part :D
Mine does! thankfully enough lol... Why is that exactly? Seems a bit random lol..
Umm.. power window motor for the front passenger?
Air con plastic shroud? Gonna silicone it otherwise.. :(
Cheers
gday there mate
how are ya
just wandering if you have any front corner indicators next to the headlights pair of them
as well as the front bar indicators the orange ones lying around
also forgot to ask about the front pair of sun visors and roof handles for all round of the interior ,
can you hook us up a price sent to sydney .
or can swap you for some brand new or used goodies you might need to build up your slider man
let me know hey
and wil speak to you soon
take care
cheers anf
Edited by DRIFT RACING INDUSTRIES
  • 3 weeks later...
    • It can't be some stupidly proprietary video signal coming out of it that only Nissan's can understand. Surely you can just find some generic camera to stuff in there and use hot melt glue/blu-tac/gaffer tape to hold it in place if need be?
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
