First I Had Pigeons, Now I Have Little Birdies Chirping When Im Slowing Down!
ok
changed my thrust bearing around 2 months ago, but recently only when i am SLOWING down, regardless whether the clutch is engaged or not, there is this increasingly loud bird chirping noise...
when i turn left while slowing down the noise gets louder... so im thinking wheel baring? or something else got to do with the suspension?
cars going to pedders tomorrow for a 28 point check, hopefully they can pick it out if not, could it have anything to do with gearbox even though like i said, whether im rolling or de accelerating it still makes the noise..
thanks in advance
usually a geabox noise will change when changing gear or accellerating/decellerating as the rpms in the gearbox constantly change with the gear/engine mix, if itsa constant noise, look at wheels... are your pads getting low?? could be the screamers on your pads. they start to squeak lightly when they are getting low, and scream when they need replacing. just bend them out of the way if you dont want new pads yet.
i just chased this problem up for a mate with a rex, we were chasing suspension noises, tyre noises (he has semi slicks), rubbing noises, and then realised that it was the lhf wheel bearing, it died as the rex has coilovers and semi slicks and he loves smashing round a bouts, putting alot of weight on the lhf. it would only do it when warm, which i thought as we are having hotter days now, that the lhf semi was becoming ultra grippy or worn enough that it was getting sweaty and slipping.. but nah, it was the wheel bearing.
ill sus out the pads but they should be fine.. replaced them not that long ago... out of what you suggested, its most likely wheel bearing..
are they an easy fix? or it something only a suspension joint will do?
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m. Or is the easiest solution to reshim the Nismo diff to make it looser?
