hay guys still got the flutter proble with my 32 gts-t was watching youtube, there was a car doing the same thing as mine it is called compressor surge dose anyone know how to fix this proble? is it because my turbo is boosting 2 hard 4 my car?
my mods are power fc,z32, fuel pump, adjustable cam gears, gtr injectors, and a vg30 turbo witch has been complete rebuilt duno the specs.
https://www.sau.com.au/forums/topic/244268-compressor-surge/
put a plum-back/recirc BOV on it.
Simple.
Thats pretty much your answer.
Reason you are getting the 'Dose' noise is because the air is being pushed back into the turbo = Compressor Surge.
The whole point of the standard plum-back / recirculate BOV is to prevent Compressor Surge. Air gets pushed into the intake not the turbo.
You DON"T want Compressor Surge or say good buy to your turbo.
Please explain how "flutterz" does fuly sik damagez to the turbo?
Turbos are designed to flow uni directionally, IE, no matter how much air you force backwards through a turbo, it won't move, it'll sit still. Force air the other way, and it'll spin. So really, flutterz can't even slow the turbo down... What does slow it down is the fact the waste gate stays open the whole gear shift IF you don't run the pressure source off the manifold... :blink:
I run a T04R on my R33, and have ZERO lag or anything between gearshifts, and I have NO BOV, purely because I run my pressure source off my manifold.
Geez, compressor surge while loaded up.. havent seen many of those on the dyno..
but its generally when the compressor wheel supplies more air than the engine can actually swallow which does happen...
Bov wont fix it... ive read alot of articles on this sorta stuff, but havent ever put any into practice... i reckon try with lower boost settings, or change the turbo...
Its generally because the inlet wont allow more air in, so it reverts back the other way n causes the flutter on load.. :blink:
  • Like 1
This is from gofastbits.com
Compressor surge: You can think or surge as the point at which the compressor blades begin to “slip” in the air, losing their pumping ability, much like an aircraft wing loses its lift when it stalls. In a turbo, this happens in a series of bursts, as the blades slip, then bite, slip then bite. This sets up a pulsing wave in the turbo piping and explains why the sound has that characteristic “flutter”.
The interesting thing about compressor surge is that it occurs much more readily at low turbo shaft speeds. At these low shaft speeds, on road cars this is generally between 2000 and 3000 RPM, compressor surge is not much of a problem, as the loads generated by the surge are miniscule compared to what the turbo encounters at high boost. However, if surge occurs at high RPM and boost, it is possible to reduce the turbo life and/or damage the compressor.
" However, if surge occurs at high RPM and boost, it is possible to reduce the turbo life and/or damage the compressor." okay well question answered i guess however i still hear of many people doing this with larger set-ups with no worries.
bigger cams, ported heads, bigger turbine a/r, smaller compresor a/r are all things you can do to try and get the turbo away from the surge line.
if that doesn't work, you need to select a more apporpriate compressor for the engine airflow characteristics.
my car does this on part throttle around 0-5psi boost, boost just jumps up down constantly, you either have to gun it or downchange to get the load of the engine, really anoying.
if it does it on full throttle, you can cause big trouble and should tend to it immediately.
i'm guessing the turbo you have has some old school t4 compressor wheel on it, designed for low shaft speed, high airflow, when it's mated to a high speed small a/r t3 turbine you can get bad results.
hi
when we speak of compressor surge there are two that come to mind
#1
when you come off the throttle without a BOV the pressure must go somewhere
so it collides midflight and causes a massive pressure spike on the compressor side of the turbocharger
the massive spike in pressure causes the compressor wheel to surge in speed
this is usually seen by the "vl turbo tutu tu tut tutu" noise on gearchange or backing off on the throttle
#2
this is less common but does occur, the compressor wheel goes past its efficency zone
and the speed of the wheel flies past the compressor's fastest's speed
the end result is that pressure past the compressor wheel is higher
than what the compressor can actually supply.
ie the compressor wheel is XYZ variant and can supply 45lbs of airflow at XYZ turbine speed
but it surges as pressure past the compressor wheel is actually 51lbs of airflow, thus the compressor wheel surges
if you have #2 i would check the turbo specs, check your boost control systems
check your intercooler pipework and intercooler core
something is making the pressure spike past what the compressor can supply
if possible measure pressure at plenum and pressure at turbine outlet
The turbo i now have was having this problem, was coming onto boost way to quick, my turbo was back cut so the boost would come on later and stop this happening, here is a link the thread which has all the r&d in it and some usefull info for you http://www.skylinesaustralia.com/forums/35...-9b-t22706.html easiest way to fix it is to either back cut your exhaust wheel or get a good boost controller that you can set up so boost is limited at certain rpm's, mine hits 14psi at about 4300rpm.
Edited by W0rp3D
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
