  • Replies 151
Posted Images
Michael it was my car you drove from Ben's shop :D
I'll be keen to meetup with the Stag boys as well, i'll see if i can make it this week, if not next week will be better for me, thanks for the invite GoldZilla :D
And Tony, that's a very nice V-Spec II you have there, very jealous :banana::D
Thanks Eugene,
The VSPEC has been a long time coming & its one of those special Toys that you never part with; It was a one owner car in Japan with heaps of Nismo gear never had any accidents or paint and its a realkeeper so I decided to give it a bit of TLC.....BTW finally got the cooler on the AXIS, no real noticable difference in Power, will just have to wait until the thing is completely remapped. The the reo needed some trimming and wasnt a straight fit with a bit of stuffing around....I'm sure it will serve its purpose during the hot summer months.
Cheers
TT
Thanks Eugene,
Cheers
TT
How much stuffing around?
Jamhe77,
Like most of these intercooler kits, there's always a little bit of trimming to be done here and there, the reo bar needed some aluminium shaved off at both ends where the intercooler end tanks finish and slots for the stock cooler needed top be cut off so the Greddy clears nicley......now its sits perfectly behind the Bar.
Cheers
TT
Hey Tony, any idea when this tuning is happening AND how much your tuner will be charging?
I don't mean to be impatient, but I am looking at either doing this or having my eManage Ultimate installed and tuned.
Got the money and the unit for the eManage, but would like to weigh up my options.
Mate once he's cleared some cars out next week (There was a flood of Porsches he was tuning) ....he'll be focusing on the AXIS, the plan is to pick up my Christmas project which has been hibernating for more than 6 months and then book in the stagea. I'll find out some indicative pricing for you; at this stage I'm waitng for the green light to drop the car off and it looks more like we will venture into the new year before I have any raw info to share.
Cheers
TT
Cheers
TT
No problemo.
Thanks for the update.
  • 3 weeks later...
Thanks Eugene,
Cheers
TT
just a question , what type of cooler is fitted to your m35 , cost ???
Greddy complete kit with piping, I purchased it from one of the forum members for $1K, now with the dollar its probably close to $2K to bring it in.
and for we VIC owners... How often would it need to be re-tuned?
Jamhe there's no need for retuning unless you're making any other mods to the car like upgrading turbo etc., once the car is remapped and performing at its optimum efficiency there's no need for any further messing about.....remember the main objective here is to achieve sensible power gains offering excellent drivability without having to consider wiring up piggy back options.
To answer your question "Still waiting for a slot to book th car in"
A standard BMW 335 twin turbo with no mods other than a complete remap of the ecu produced 235KW at the rear treads....remember that these cars produce 225KW at the fly in stock trim. Now I've heard of other 335's making close to 260KW at the wheels with turbo back exhaust & intake mods ,either way there is alot to be gained just from remapping a standard car.
The XR6 Turbos have achieved amazing gains through ECU retuning without piggyback systems...and this has been the approach that I have opted for once the car in completely tuned with the mods in place i.e Turbo back exhaust & Intercooler upgrade theres nothing more to do other than just enjoy it....right Now all can do is wait until there is a time slot to book the car in.
Thanks, that puts my mind at ease.
I foresee an possible intercooler upgrade, then roadtrip - already got my HiFlow and exhaust :P
May even be able to convince some Vic M35's to take the trip as well.
gotta say though... it's i amhe77, not jamhe77.
Again, thanks for the info Tony.
Much appreciated.
Much appreciated.
HOPE I HAVE MY CAR WHEN THE TRIP IS ORGANISED :P
Just to keep you updated, car will be booked in next week for a comprehensive tune....whilst I'm away on holidays I've managed to squeeze in the cue and book it in as they have 10 days to play with the AXIS and achieve the best possbile results, this will also remove the speed limiter and possibly tighten up shift points on the gearchanges as well.
Fingers crossed should have some respectable figures for everyone in a 2 weeks time.
Cheers
TT
Cheers
TT
Perfect timing Tony. I look forward to seeing the results.
Cheers
Andy
Cheers
TT
YES!
Look forward to the results Tony.
Quick Q though.
If the battery happens to die, fuses replaced or the car is taken to an over-zealous dealership and they do a "factory Reset", will it reset to "factory" settings or to "tuner" settings?
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
