ok guys,
I've recently fitted a brand new Garret GT3582r with a .63 rear housing with the internal wastegate machined and a much larger wastegate flat added. Fabricated my own Bellmouth dump pipe, which is all mounted on a DMAX exhaust manifold.
My problem lies with the wastegate, Had it on the Dyno yesterday and found even the much larger internal gate was wide open with an 8psi actuator but boost was climbing well above 19-20psi and still climbing. I kind of expected a higher boost level than the 8psi actuator but wasn't expecting this much. Being an Unopened rb25det i am trying to keep it sensible. Yes i have checked to see if the dump pipe i made is fouling the wastegate flap and its not. hehe
My options are:
Either pull the turbo off and fit a .82 rear with an internal gate hoping this will help with the issue but i sacrifice any response i was trying to keep with the .63.
Fit an external gate (38-45mm?) to either the DMAX manifold or to the .63 exhaust housing and hope it gives me alot lower minimum boost level.
Who has encountered a problem like this and what's the best, cost efficient way of getting around this.
https://www.sau.com.au/forums/topic/244319-rb25det-gt3582r-my-predicament/
Check with BHDave, or search his threads. He had boost control issues with a GT30 0.63 combination. I suspect you'd be dealing with similar issues.
With that spec turbo you'd have to be chasing some pretty big power output, and an 8psi actuator seems seriously underdone. Go to a 0.82 A/R housing and fit a 14psi actuator at minimum - choose an actuator that is close to your intended boost and fine tune it with your controller from there.
If chasing high output from your RB25 then I hope your plans and budget extends to engine hardware upgrades - it will only stand being leaned on for just so long before something gives out.
Keep on it, and keep us posted. Very keen to hear how this combination works especially if you have a manual transmission. Hopefully your turbo supplier is willing to work with you on this one.
It may seem like a stupid turbo choice i know, but i really like the fact i can flat throttle it off the line in first and second and it's just fast enough not to break traction. A 3 litre bottom end will replace this motor once something let's go, Just eager to see how reliable this sort of thing will be. I really wanted to keep the .63 rear housing as i want as much response as i can get my hands on. I've had responsive turbo's now keep for some higher numbers with more aggressive power curves.
Any more info on external gate setups will be greatly appreciated.
yea i assumed the 3L would need a .82...Im not too concerned about that just yet as that's a fair while away. I want to get this layout fairly good first.
Anyone's thoughts on External gates welded onto Exhaust housing of turbo? My manifold doesn't have a large collection area where i can plumb into it.
Your custom dump isnt blocking the wastegate flapper is it?
EDIT: Its one of 'those' manifolds... ugh i really dont like that design at all...
Why didnt you go the other way? Choking the turbo is the wrong way to do it IMO.
Correctly sized rear housing (.82) and then a GT30 compressor wheel (500hp) would be the way to do it... or if you REALLY want proper response, .63 with the GT30 (GT3071/3076 style) - not the GT35!!!!
Then sell the turbo, and get a GT35 when you get a 3ltr. :blink:
They hold value near enough, and with a GT30 - 270-280rwkw... the RB25 you might find will probably last you a fair few years...
So you would be waiting a fair while i reckon for that 3ltr and in turn can go all out with a big GT35 on a full build, 1.06 housing, 400rwkw etc.
Remember the GT35 wheel is a 700hp wheel or there abouts. Putting a .63 on there means your basically hurting turbo output for no real reason (response doesnt count as a reason if you get the correctly sized compressor wheel).
All of that restricting will bring the flow down to a stab of around 550-600hp worth of top end air. Not good at all as you then bring heat, backpressure and other nasties into the equation.
Just my thoughts on it
not sure why it is overboosting, have a good look at the gate and actuator.
there is a jpc vl with 0.63 housing on gt35 running 9's (370+rwkw), so it can be done, just not the obvious choice. (or logical, but who can argue with the results)
the turbo you want would be a gt3076, good front to rear ratio with regards to gas flows, no point of the gt35 82mm front with a gt30 rear wheel. aka gt3082 bad match
Edited by RB30-POWER
Have experiences with an rb25 with an 3582 .63
external gate 38mm, holds beautifully, which just a dual stage bleed valve (no ebc as yet)
Logic would tell you me that if your having boost control issues its from your wastegate or bc.
size of the rear end will just cause lag etc as explained above.
3582 may seem big for a stock 25 but comparing to say a GT30, the 35 may come on a bit later but when it comes its well worth the wait, just an effortless tyre fryer.
So its 100% that the housings and/or turbo aren't modified? :D
Was it done on PULP?
Cause i mean, if people have modded housings and non-standard fuel, it totally changes the dynamics
So its 100% that the housings and/or turbo aren't modified? :)
race fuel, modified + 50mm external gate :D
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
