Yea but im sure that rb30 was build to handle 30+Psi lol
Can front wheels and covers be swapped over like rear ones?
Yes they can but you will find it is a very expensive exercise! Rear housing from Garret from memory was $600+
And yes +1 to a .63 housing being way to small on a 3L it will choke up for sure IMHO it is a bit of a misfit size in the Garrett range...
The .82 is not too bad on a stock RB25 more suited to a built motor but it will be a good balance between not having to buy a new turbo when you get the 3L cause a .82 on a 3L is a response monstor :domokun: I personally have a 1.06 rear on my 3L and wouldnt have it any other way as it feds on the power so nicely. Also I might add mine is internal gate and am having no problems with boost control 7psi actuator and a Turbosmart T and holds dead on 15psi.
And is it definately internal gate?
hahaha
Thanks for the info guys, For now i think im going to wire the Internal Gate shut, Mod my manifold to house an external gate and still use the .63 rear. I like it at the moment how i can cruise around at the moment like everything is normal but flat foot it off the line in first and it doesn't break traction. If the .63 generates too much heat ill put an external gate rear .82 housing on the turbo and keep it that was until i wack it on a 3L.
Thanks for the Info.
Hey guy,
I think 'the mafia" did a gt30 with a .63 rear end. Search for his threads. I dunno if you're already onto it, but it makes for a good read.
Also, just something I would consider if I was in your shoes... Why don't you use the GT35 with a ext gate setup until you get your 3.0l
from what everyone on hear says, the ext gate spools the turbo quicker, and then you have an upgrade path. You may or may not want a .82 rear house when you 3.0l, but that's then, not now.
The .82 is not too bad on a stock RB25 more suited to a built motor but it will be a good balance between not having to buy a new turbo when you get the 3L cause a .82 on a 3L is a response monstor :( I personally have a 1.06 rear on my 3L and wouldnt have it any other way as it feds on the power so nicely. Also I might add mine is internal gate and am having no problems with boost control 7psi actuator and a Turbosmart T and holds dead on 15psi.
hahaha
You have the XR6T version yeah? with the 0.50 front cover?
How does that affect compressor flow?
I do but also have a .7 cover
There is no noticeable difference between the .5 and .7 without changing the tune, might get some gains when it gets retuned though...
I have found that bigger turbo's with low boost make heaps of wastegate air. So if the gate is too small, and or the waste gate dump is to small, the issue comes where the gate cannot dump enough gas to stop the turbo from spooling up.
yea we figured that one out, going external gate so will resolve that...I was talking more of whether the .63 rear can flow enough through it to cope with the gt35 front cover and the volume of air its producing to not create too much heat.
If i were in your predicament, i would seriously consider selling it and buying a proper matched turbo. As you seem aware, a 3082 is behind the 8 ball, as teh ex wheel is too small to generate enough torque to accelerate the rotating mass quickly. And by using a .63 exhaust, it is partially alliviating that, but adding high backpressure to the equation. I would be fitting a .82 3076, as IMO it is the ideal turbo for an rb25 after 280-300rwkw. Even if you fit the rb30 (which i dont think you will need to)the same turbo can be used, and fry the tyres up to the legal speed limit with more response than you can poke a stick at. If you feel you must have more than 300rwkw, then bite the bullet and get a real gt35r, with a .82internal or you can get away with an external gate .63, but i believe on pump fuel the exhaust backpressure will limit the power to far less than the comp wheel is capable of making. We need something between a gt30 and gt35!
i find this topic interesting....
Just incase anyone cares...
my gt35 with .63 rear isn't as laggy as you'd originally expect.
3000rpm = 0.56bar 8psi
3500rpm = 0.82bar 12psi
4000rpm = 1.04bar 15psi
Once external gate is fitted should be fairly good.
Just hoping the .63 rear doesn't choke up the gt35 housing too much in the top end. For the conservative boost ill be using it shouldn't.
^^ thats fairly laggy IMO.
I had my GT30 .82 on by 4200rpm and was over 15psi and make more power than you will be able too :yucky:
500rpm to get that last 3psi once spooling is indicative of the large compressor side
after 4k the boost sky rockets but thats when i back off, yet to see what it does after that.
yea but at the end of the day, It's all about experimenting....gimme a break...i just spend 2k on this turbo, gotta stay positive hehe.
I'm not doin it to beat anyone else...doin if for my own thrills.
It's fairly laggy i know but off boost it drives great and doesn't break traction which is what i was after.
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
