Car was purchased in April this year from Sydney and driven back to my home in Sippy Downs. Car has been garaged and well looked after. Serviced every 3,000km's with Motul Oil and Oil Filter. Car worked on by MW Performance on the Sunshine Coast.
PRICE DROP $21k - WILL TAKE ANY OFFER OVER 19,500 CASH IN HAND (with stock rims and no plates). Prepared to NEGOTIATE.
Would consider reducing price of car if performance mods were removed from vehicle. Happy to remove certain things to lower price.
Car has been run on BP ULTIMATE 98 Octane its entire life. -At present, car runs around 400-450km's per tank.
I welcome any questions and inspections on the car. You wont be dissapointed. Welcome to all reasonable O.N.O's - Reason for sale - Car is not used as often as i would like and is surplus to my needs. $22,000,Wont find a better price anywhere.
List of mods and prices of mods as follows:
Apexi AVC-R Boost Controller - $650
Apexi Power Intake Pod Filter - $89
Cold Air Induction Box - $150
Walbro 500hp 255Ltr Fuel Pump - $190
Whiteline Sway Bars, Front and Rear - $520
Cusco Rear Strut Brace - $210
Nismo Front Strut Brace - $100
Cusco Subframe Strut Brace - $150
Tien Super Street Coil Overs - $1680
Super Pro Subframe Bushes - $100
Hicas Lock Bar - $99
Full Tubro Back HKS Super Silent Exhaust with High Flow Cat - $1600
Splitfire Coil Packs - $529
Irridium Racing Plugs - $139
GREDDY timing belt
New Water Pump, Idler Bearings, Seals and pulleys. Includes new ancillary belts, 100,000km Service (done 30,000km's early) - $1,000+
Nismo Thermostat - $149
40mm Racing Radiator - $399
Cooling Pro Stealth Loop Kit Legal Intercooler - $550
XHP 18" Rims with 95% Federal Tyres - $1,900
Nismo front and Side Clear indicators - $110
B Pillar Strut Brace - Inside Car - $129
Alpine CD Player with 12" sub and 800watt amp - $600
Turbo Timer - Came with Car
Tinted Windows - $170
Nismo Gear Shifter. - $69
Link to images: http://www.carsales.com.au/used-cars/priva...amp;distance=25
PM OR CALL/TEXT on 0401637722
Edited by sunnycoast
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
