He's right it does work at low speeds. I think its called opposite phase or somethin at low speeds. It turns the wheels the opposite direction to the front wheels at low speeds. and at high speeds in turns them in the same direction as the front wheels.
Or if you don't enjoy unexpectedly being wrapped around a pole if you can't help booting it around corners. :)
It's not that it 'has a mind of its own' every time u boot it around corners. Sometimes it does it and you won't realise. But in my case when it swung me lane to lane, you obvs realise it and it becomes a hazard. I just got lucky, if it kept oversteering about 20cm more I woulda wound up over the box curb in the bushes. No point fitting it in after you crash it. Rather be safe than sorry imo.
Edited by Magic
it does work at low speeds because if i slow down for a turn and then gun it round the bend quickly it brings my back end round nicely, sometimes im not sure if it is the HICAS or me losing traction. i quite like it but then i have not had the car going hard round a track or a skid pan yet. am booked in to take it on the skid pan at AHG next month so i will have a better idea then and make my mind up wether i still like it.
That doesn't make sense.. HICAS would be working whether you gunned it or not (if it did in fact work at slow speed) and it wouldn't suddenly snap in when you apply the gas.. sudden dynamic steering changes mid corner upon application of accelerator? lolwut? do you have traction control on when doing this? Maybe it works differently on 34s? I'm still rather certain HICAS (at least in 32s) does nothing at low speed.
Found this, it pertains to HICAS in 240sx's.. can't be assed researching more right now.. so the question for now is: what is "moderate" speed?
Edited by bubba
Did some more research on it too and this website on the 240SX HICAS justifies mine, Ruckers and Steve's theory on it. And if it does this on the s13 it would no doubt have the same effect on 32s and above.
http://www.240edge.com/basics/super-hicas.html
Not sure how credible it is though. Would prefer to see pictures/info from Nissan itself.
I guess it doesn't really matter if it does/doesn't work at low speeds as its not really the issue. At the end of the day, lockbar is the go.
That image I posted above is from Nissan..
As for the speedo, it depends what has stopped working.. if it's the cable then no, HICAS won't work and neither will your speed sensitive steering. If the problem is after the cable (i.e. the speedo itself) then HICAS and speed sensitivy steering should still work (n.b. this only applies to S13/R32)
im having problems with my electric HICAS on my 33 ... it comes on after turning off the engine for a short while, im probably gonna
get a HICAS lockbar and lock the crap out of it !!!!! KYP in Wealshpool quote me 170 fitted .... is that an alright price ??
cheers
wtf? what makes you say HICAS is killing the engine?
that sounds pretty fkn strange..
no no .. nothing to do with killing the engine, just that when i drive around and i switch my car off for awhile ... when i come back and
switch the car back on the HICAS lights comes on and i lose the power steering.. LOL
Lol, thas kind of like mine atm.
I will be driving and the steering is a bit resistant then hicas light comes on and become some what hard to steer lol so
Im just getting the whole thing removed That way i save precious Kg's :D
It will all be fixed soon!!! ;)
ive teared it up @ ahg skid pan day and ive still got my hicas active. It didnt bother me too much tho. But then again it depends on what "high" speed and "moderate" speed is...
Top speed on a skid pan day if ur lucky is 100kmh.
Only to then slam the brakes and rip around the corner.
Booked in another one in dec... see how that one goes.
you doing it on the 14th of December? im booked in to do it then.
Don't you mean the 13th Dec? or is this not the SAUWA day?
If you mean the 13th like bubba said, then yep i am booked in then. The arvo session tho..
Nah sunday 14th not the SAUWA one. my parents got me it for my birthday. was ment to do it on the 16th of this month but coil packs went on me so had to move it to next month.
im having the same issues want to remove mine aswell,..to dangerous in the wet when sideways gets to unpredictable hicas gets confused..but i have a feeling that mine is affecting my powersteering as it gets really hard..almost like no powersteering at all..when car is just started in the morning the powersteering works fine but afta a while goes hard..has anyone else had this problem or could it be sum other electrical issues..
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
