Well after deciding to sell the car, i thought i should clear out under the bed. All prices are negotiable within reason, I would like this stuff gone before christmas so why not buy yourself a gift and help fund my trip overseas :D
Any questions feel free to call:
0402312197
Item: Garret gt30
Condition: excellent (USED)
Price: $1500
Comments: Has been modified on the hot side to accept waste gate on the housing, this was done so it could be used
on standard manifold. this can be blocked off to be used as normal.
Item: Power FC + Hand Controler
Condition: NEW
Price: $1500
Comments: Suitable for rb25det series 1
Item: Power FC Boost Control Kit
Condition: NEW
Price: $500
Comments: Suitable for power fc
Item: Bosch 044
Condition: NEW
Price: $200
Item: Aerospeed Adjustable Cam Gear
Condition: NEW
Price: $150
Item: Sard 550cc Injectors with collars
Condition: NEW
Price: $900
Comments: Bought to Suit RB25det P/N: 195500-2240
Item: Z32 Air Flow Meter WIth New Plug
Condition: Perfect
Price: $250
Item: Nismo Fuel Pressure Regulator
Condition: NEW
Price: $150
Item: Highmount stainless Manifold, excellent quality
Condition: NEW
Price: $600
Comments: Includes genuine nissan gasket worth $95, paid $700 for the mani.
Item: JJR Inlet Plenum
Condition: NEW
Price: $450
Comments: comes with all the fittings.
Item: Standard Coilpacks X6
Condition: Good
Price: $150
Comments: only seen 75000K's
Item: Waste gate 35mm
Condition: NEW
Price: $150
Item: Stock Rims R33
Condition: USED
Price: $300
Comments: Near new rubber on two, the other two are still very legal
Item: R400 Front bar
Condition: $500
Price: NEW (unpainted)
Comments: will throw in the indicators
https://www.sau.com.au/forums/topic/244378-performance-parts/
  • Replies 40
    • Definitely didn't put a N/A cluster in instead? The speed sensor (location) is different in both cars.... I think. This will obviously stuff things up.
    • Nah not the throwout bearing, it's something internal. I already replaced the throwout bearing. Mechanic misdiagnosed my car and thought it was a spigot bearing, went to another bloke who said it was an input shaft bearing. (I replaced everything when I pulled out the gearbox but didn't open up the gearbox.   In this video at timestamp 6:05 : Mine has the same sound  min
    • It is definitely to space it out and away for clearance during compression, and possibly for spring clearance to upper arm. That latter would only be true for springs that are same-ish diameter to stockers, and so that probably doesn't apply to Teins or most other coilovers.
    • Yeah, a mechanic who knows these cars told me even if I get a brand new gearbox the noise will return but will be less noticeable. I've heard someone also they this noise came back after 3,000km on a new or reconditioned gearbox. It is pretty f**king annoying though just hearing groaning most of the time lol. I wonder if an aftermarket input shaft bearing would fix the problem or how they are built.
    • All RB gearbags, especially the big turbo box, have rollover noise. Mine certainly does. Always has. Sometimes is worse than others - no particular idea why, although it is probably temperature related. I have smurf jizz in mine and have had to have it in there from the first day the box went into teh car. It simply would not select gears with the engine on, on day one, with normal oil in there. And so, the blue stuff has probably ruined almost everything synchro related in the box. But it has taken 12 or 13 years to get to the point where I simply must replace the box. It has become increasingly baulky of late, which might be symptomatic of the way I've been driving it, as much as anything. I shall have to make some corrections when teh new box goes in. Input shaft bearing noise will decrease with clutch pedal pressed because the drive is removed. But yes, more often than not noises that work like that are associated with the throwout. It won't matter either way, new box will mean this one can be relegated to the parts pile.
