Hi all,
Im after a hi-flow drop in panel filter for my stagea. Im aware I can get a K & N at pretty much any large auto shop but i dont really want one of these. What else do you recomened and where can i get it here in adelaide?
Cheers,
Chris
https://www.sau.com.au/forums/topic/244395-drop-in-panel-filter/
I ran a ryco panel filter and made upwards of 300rwkw.
Recently dropped in a BMC panel filter; induction is a tad louder.
Where did you get ur bmc panel filter?
Edited by kidafa
so all this talk of pod filters, is really not true?
they dont have a huge benefit?
I have a modded airbox. 100mm CAI cut in to the bottom of the airbox that leads in to the front inner bumper. This isn't possible to do with the R33's.
If you can setup a good CAI in to the stock R33 airbox I'd say its easily good for 300rwkw and better for hot weather.
I've tried a pod in the past and found a very noticeable difference in warm weather. The car noticeable feels gutless with slower spool.
All though the 3ltr masks it I don't notice a great deal of power difference in hot weather.
Autobarn. $113 from memory.
Was an impulse purchase. Went in for the usual ryco spotted these and thought bugger it. Its about time I spent some $$ on an air filter lol.
How long has this air box vs pod filter debate gone on for?! Hahaha...
Some say there's barely any difference when driving at speed, but when stationary, sure - a unshielded pod will be sucking up air which is 70+ degree's. Pod + shield + snorkel = win.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
