Lines In Cairns
heh
i grew up in cairns and my grandparents live on teh tablelands
(mareeba and malanda and formerly tolga, just outside of atherton)
ive seen a few soarers (but no skylines) while ive been up there;
https://www.sau.com.au/forums/topic/24449-lines-in-cairns/#findComment-522834
Originally posted by Spooks_Skyline
heh
I am staying in atherton and working down at the tinaroo dam, we are building a mini hydro electric powerstation at the base of the dam.
Lots of old people around here and lots of old 4wd's around.
https://www.sau.com.au/forums/topic/24449-lines-in-cairns/#findComment-522978
I spose a Skyline doesn't make much sense up in the tropics. Its to hot and the roads can't be that great. Although the roads in Townie were OK. They had great wide corners without much traffic and with nice smooth long straights. Leewah was there aboout 2 weeks before I went up and thought that out near the airport in Townie there are some wicked long stretches where his monster could have had a crack at the big three zero zero.
Both Leewah and I agreed that our Lines should go with us next time.
https://www.sau.com.au/forums/topic/24449-lines-in-cairns/#findComment-524494
Around where i am the roads are really nice and smooth, but they are very narrow so if a truck is coming the other way u have to put 2 wheels on the dirt to avoid a head on.
I got the shitty BA falcon upto 210 easily, leewah could wind out 300 around where i am easily!!
https://www.sau.com.au/forums/topic/24449-lines-in-cairns/#findComment-524496
Hi fellas,
I'm a Cairns resident and will be back in town on Thursday with my latest acquisition. Metallic black R34 GTT (plated 34-GTT). It has some mods but nothing too over the top. I think I'm going to have to do the Rex Range Rd up through Julatten and Mount Molloy as soon as I can.
There are a few Skylines around. The boys at Autobarn in Cairns tell me that there is an R34 GTR in town as well but the guy only wheels it out on weekends.
Cheers
https://www.sau.com.au/forums/topic/24449-lines-in-cairns/#findComment-528766
I'm up around The Port and Cairns for my honeymoon in mid-late october this year. Hope to see a few 'lines to remind me of mine at home in bed (and to piss of the wife when i start waving frantically and yelling, "Skyline SKYLINE LOOK !!!! AAAHHH!!!"
umm.... ;)
does anyone else do that?!?! thought so :D
Adrian
https://www.sau.com.au/forums/topic/24449-lines-in-cairns/#findComment-529035
    • Photo of manifold showing gate location? I mean, it's 6Boost, so we probably shouldn't be worrying, but always wroth knowing what the layout is. Plumbed back to atmosphere? Or into the dump?
    • Yes correct. Also, I'd avoid applying it to soft paint (however I doubt you'll ever have to deal with it in practice). So any paint that hasn't fully hardened, could be a 1k paint that never fully hardened or it could be a 2k paint that was laid down thick and hasn't yet fully hardened.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
