about to buy some gearbox oil for my r32 gtst and went to the guys at super cheap...i know that some people ehre recommend using 75w-90 full synth...so would this be good to use for my car which is a daily and will never see a track day?
at super cheap there was some nulon in 75w-90 which was semi synth so just wondering if this would work well with my gears being very notchy from 1st-3rd?
the guy there told me to put in 80w-140 because of the notchyness of my gearbox and just wanted to make sure thats o.k cause its far from what most people recommend?
can anyone else recommend something around the $40 bracket for our cars?
https://www.sau.com.au/forums/topic/244507-gearbox-oil-for-r32-gtst/
Castrol syntrans l think it was, it was recommended to me by our castrol supplier and l tried it in my old R33 GTST and it made a noteable difference, mainly with fast shifts(no more grinding) its more expensive then normal but worth it. Not sure what the grade was, but close to factory specs.
hope that helps
castrol vmx80 or penrite manual gear oil 80
correct grade for these boxes, designed for boxes that are notchy when cold, i.e. nissan rb gearboxes.
if you have problems when it's hot, most likely the syncros and baulk rings are stuffed and only a rebuild will help.
vmx80 did the trick for my notchy 2nd gear. No more notchy 2nd now, even when cold.
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
