Unfortunatly my baby has to go i love this car and am sure the next owner will as well!!! Bought from AutoStyle where ALL mods were done professionally! Engine mods are as follows: upgraded turbo's bigger injectors bigger fuel pump (in tank) aftermarket adjustable cam gears aftermarket cams complete exhaust turbo's back (nice and quite but still has skyline sound) aftermarket computer (APEXI power fc) car is running around 1.1 - 1.3 bar of boost not exactly sure as when you put your foot down you gotta just hang on no time too look at it. it has some aftermarket rims on it not exactly sure what they are but they look sweet its also lowered (profesionally),it also has a strut brase and also a incabin brase that goes along the back floor to make it a little more stronger and stiffer through the corners like i said this is my baby and don't realy wanna sell but unfortunatly things change!!! please only legitimate people call as i have no time for DREAMERS and NO TEST PILOTS ANY REASONABLE OFFERS WILL NOT BE REFUSED CAR MUST GO!!!!!
Runnig 290KW at all four wheels have dyno sheet to prove
$25,000 ONO
I DON'T GET ONLINE AS MUCH THESE DAYS SO IF YOU HAVE ANY QUESTIONS TEXT ME OR JUST CALL ON 0421872229
Edited by DRR33E
https://www.sau.com.au/forums/topic/244516-290kw-r32-gtr/
does anyone have anything interesting to trade will concider vx,vy commodore ss 6 speed or ford xr8 (new ford) need somethin 4 door but will concider swapping for bikes pref yamaha r1 - r6 or suzuki don't no yet maybe a kwaka not sure just ask away
cheers guys...
https://www.sau.com.au/forums/topic/244516-290kw-r32-gtr/#findComment-4260238
If you want to sell it so quick and it's your baby maybe you should spend a few minutes and list all your mods, show some more pics etc etc. Even where you got the work done.
https://www.sau.com.au/forums/topic/244516-290kw-r32-gtr/#findComment-4274682
Thanks for the tip but im pretty sure i mentioned that all work was done by autostyle in sydney! as per what mods are done it's pretty straight forward bigger turbo's (garretts i beleive) bigger injectors , bigger intank fuel pump , cam's and cam gears , aftermarket computer (apexi power FC).
I'm sure i mentioned it all before and i do apologise to anyone if i missed anything.
It is a genuine reason for sale as i mentioned before i'm up to my knees in dept and have a wedding on the way so it must go i need the cash or swap for something cheaper plus cash i still need something to drive! anything will be considered so pm me or text or even call me anytime
https://www.sau.com.au/forums/topic/244516-290kw-r32-gtr/#findComment-4275697
Mate were not blind so no need to have the font so bloody big!
Garret turbos: What model?
Intank pump: What brand?
Injectors: Brand and size?
Cam: What Brand and Spec?
These are what people are wanting to know. The specifics of the mods...
https://www.sau.com.au/forums/topic/244516-290kw-r32-gtr/#findComment-4275989
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
