id go Jap stuff, but thats just me. Pipercross doesnt have panel filters for Skylines
just clean your current one
Lol, of course they have a filter to fit the skyline, just ask for this one:
Outside Length: 280mm
Outside Width: 165mm
Height: 28mm
To fit,
Nissan S15/14 200SX,S13 180SX,Pulsar GTiR,N14 N15,Skyline R32,R33,R34
Subaru WRX,
Commodore VL-VS V6&V8
Hmmm, if you say "Holden VS" or similar you'll get the right filter, although I had the same issue when calling around, had to say it was the same as a Holden VS filter...
  • Replies 47
Did you have a decent hi-flow panel filter in there before?
My guess is stock nissan or similar, so of course your going to notice a minor difference going from crap to a decent flowing filter setup.
If stock airboxes can make 400rwkw on BIG GTR's (with the side airbox restrictor thingo removed for the flow in R34's)
Good enough for run of the mill setups below that, plenty of threads on it, Dezz even posted some dyno results which showed such little difference it wasnt worth going pods due to factoring in increased intake temps
Stock filter on the car when purchased, no idea how old but by looked old, so i went from an old stock to a new pod, the minor difference may have been the same just by putting a decent panel filter or maybe even just replacing the stockie? Will probably go back to a good brand panel filter soon, hoping to reduce the induction noise and after reading your quote above about the increase intake temps thats the last thing I need living in Queensland.
Apex-i panel filter (or similar non oiled filter) in the stock airbox...
Been using one in my car since the beginning, and still doing the job with the current power output....No issues with response whatsoever.
Thanks dezz!
Any idea where i can find one? Are they on Just Jap or somewhere else?
Always ordered mine from Nengun in the past...they're good for about 25,000km so 1 a year would be more than enough for most people...
I'm sure Just Jap or similar would sell them...Never really checked. A trader on here (Kudos maybe) also had some at one stage....I might have even got my last one off him come to think of it...
Blitz also sell a non oiled panel filter, but I've never used it personally.
Thats like banging your mrs backdoor and not using the lubricant. lolz
LOL!
I have lost count on how many sexual reference comments you have made.
I wanna goto Centrefold Lounge, havent been there before... :)
Ofcourse they do!
http://roccosperformance.com.au/shop/index...products_id=308
But I don't know whether to get this, or the Apexi one for a few dollars more
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=110308208089
or to just stick with the one I have which is about 25000kms old. :)
Edited by webng
Height: 28mm
To fit,
Subaru WRX,
opoos didnt read it thoroughly :yucky:, now this may be some good panel filter.
+1 not using oil filter , i have a mint 1 laying around red foam oily. didn't want to use it so i bought a blitz one..
im just going to throw this out there but i had a stocko box and now have an eclosed box and the only reason i did this is not because i noticed some neck snapping increase in power but because i like the sound =)
well that confirms exactly what i thought.
Going from a unknown stock filter to a pod is of course going to give you something of a gain.
Hell the filter in there could have been 5+ years old!
I can help with an A'PEXi panel for $101.20 delivered via Express Post, these can be found within the following thread within our trader section:
http://www.skylinesaustralia.com/forums/A-...-R-t244157.html
just wanna add that now that its summer, my under bonnet temps get very hot now, i have an in cabin thermommetrer that reads the temp around the pod filter and its been getting up to nearly 70degrees celcius, a massive decrease in power on these hot days and i tend to use more fuel aswell, on open roads or cold days the air intake temp is the same as the atmosphere temp,,,,, I got an apexi pod that is uncovered and i believe i would benefit from the stock box with highflow panel or an enclosed pod that is shielded from some of the engine and turbo heat. But for on the track i cannot see how the heat would effect the air intake temps purely because of the amount of cold air being thrown into the engine bay at high speeds.....
drifting is another story completely and if i was to drift allot i would definately shield the pod or put standard box back in...
Decided to test the difference yesterday, took the car out for around 30 min with the pod for some semi spirited driving with an outside temp of 28 deg (10.30.am). Then came home opened the bonnet, waited for it to cool, ripped off the pod, mounted the original filter box assembely completely as standard, standard flat panel filter (The original one i took out) and took her out for another spin. Took about 50min to change over all up and be back in the car. This was for my own testing purpose only and i can't say it will be the same for everyone but...........she is running fantastic in my opinion i have actually improved it by going back to the panel and it's not even new. Note that i had no form of CIA and the pod was just sitting in the engine bay where the box was, also i have the std intercooler so there was no holes under the pod either. The biggest improvement overal was sound, for me i think when i put the pod on the induction sound was so loud (all i could hear in the cabin) you just thought that performance was increased but now i can hear the exhaust note perfect and the sweet, sweet sound of that turbo winding up :P . Thankx heaps for the advice R31Nismoid i would have just considered the pod to be better before reading about the temp affects.
50 mins to put the stock Airbox back in?? LOL did you use your teeth? haha.
Iv just done the same thing, i switched back to Stock Dump/Front because the JJR piece of shit split was causing so much trouble. Now its running perfect.
At the same time i put my stock airbox and an Apexi panel filter in (had the Apexi Pod)
Overall im dam impressed. The sound is so much better, hear that turbo spool, and if your that way inclined, you can still hear induction and the BOV too. Think ill stick to the panel filter from now on. I like it.
i have a pod filter set up now, made a custom box and trimmed top half of airbox to fit the box.... for cold air as i have the stock cooler in my r34.........i prefer the sound of the pod and there is abit more response.......i was using a blitz sus power non oiled panel filter which was and improvement on stock item.......wont be going back to it now as i have hacked my airbox lol........anyone want the blitz filter drop me a pm and come pick it up! its like new..:D
    • It's not any meta data. They have scraped images from everywhere, and then use AI to compare your photo to other photos and work out where you are.
    • I just looked at my camera phone settings, apparently I have "not allowed" for location  Will that stop that app?
    • Can you not just turn it off on your phone if required? I remember a brief on this, well, I remember the brief, not what to actually do. LOL
    • Thanks for posting, your engine bay looks tops. I'm fairly sure you posted the wrong video though, I think you were supposed to upload the one from your "private test road" where it's banging off the limiter with the gate open?
    • This is something to be careful of. I did a bit of digging on the NM35, as I spend a lot of time on near brand new cars and CANBus related stuff, which uses the same "OBD2" plug for a fair chunk of making my life easy. The NM35, does NOT support OBD2. The data pin is actually on Pin3, which is a manufacturer specific pin, and requires Consult3 to connect to the NM35. Your low voltage, is either because the NM35 doesn't have 12V to the constant power pin on the J1962 (OBD2) connector, OR, it is attempting the standard comms, (CanBus, K Line, etc) and can't see any voltage on those pins. Some people have had success accessing SOME data from the vehicle on OBD2 specification, using a module that supports KPW. My assumption, like Duncan has stated, it will likely actually be JOBD, where there is some cross over with the OBD2 and JOBD standards. Note, lots of "OBD2" dongles, do NOT support KPW, which is what you need for a lot of Japanese vehicles of this era (And even up until recent years!), EG, Subaru, Suzuki, etc.    The end of this thread is probably worth a read, as some people did find a way to get a display up in the NM35 recently, looks like someone implemented all the stuff needed to make it work. (The right protocols).
