Hey all,
Brother bought this car the other week, Hasn't driven manual in 6+ years and decided the car is too powerful and finding it hard to not stall it / roll back, so has decided to go for an auto XR6T, so will consider swap. :)
So he has decided to sell it, So for the time being I've been driving it around - and loving it!!
It's a really great car, and turns heads!
I've just copied and pasted the specs from the Car Sales Add when it was for sale.
Vehicle
1993 NISSAN SKYLINE ECR33 GTS-T
Price
$17,000
Kilometres
119,000
Body
2 door 4 seat COUPE
Colour
Blood Orange
Interior Colour
Std Nissan
Transmission
5 speed Manual
Drive type
Rear
Engine
6 cylinder Petrol Turbo 2.5L (2498cc)
Reg Plate
RB26
Reg Expiry
MARCH 2009
Road Worthy Certificate
N/A
Vehicle ID
5825279
NISSAN SKYLINE R33 GTS-T S1 M-SPEC
RB26DETT
ENGINE:
RB26DETT conversion
RB26 sump w/transfer case sliced off
RB25 engine mounts
RB25 Harmonic balancer
HKS Intercooler with custom front mount position and solid piping
BLITZ 80mm S/S tuned front pipes
SIGNAL S/S (1.1mm and 7kg!) rear 80mm straight through carbon muffler
HKS Pod filters
Splitfire coil packs
TODA Racing clutch
TODA Racing 4.5kg Flywheel
CUSCO 2 way mech diff
IRIDIUM Plugs - 6's
R33 GTR fuel pump
SUSPENSION / BRAKING AND HANDLING:
SELBY rear 28mm sway bar
RACING GEAR coilovers
D1 rear camber arms
D1 HICAS lock
CUSCO front tension rod
Solid rear subframe bushes
D1 adj castor rods
PROJECT MU Slotted front rotors
TRW (LUCAS) brake pads all round - new
NISMO Front strut brace with brake stopper
GTR rear strut brace
BODYWORK & INTERIOR
Full body respray in Blood Orange
Satin Black bonnet and wing
SPARCO bonnet pins
NARDI Steering wheel
TRUST gear knob
SPARCO Spirnt drivers seat w/ BRIDE Rail
GReddy Profec B Spec II boost control
GReddy Turbo Timer
GTR Centre gauges
New Carpet
GReddy Boost Gauge
OILS
Castrol Edge 5w30
Redline shock proof diff oil
Redline shock proof gearbox oil
Redline powersteering fluid
MOTUL 600R brake fluid
Plates won't be sold with the car, will change them over to standard plates when someone wants to buy it.
Pardon the dirt on the car, didn't wash it that day because it was way too hot.
Any questions etc, feel free to give me a SMS anytime or Call between 9am-8pm
0488 908 203
Thanks, Josie.
https://www.sau.com.au/forums/topic/244524-r33-with-rb26-conversion-17000-ono/
Good luck with sale, know how fun a similar set up feels like to drive... Mine only had 239rwkw from a fairly standard 26... oh the memories
haha yeah its been a blast to drive :laugh:
But guess it got sold today. (to DamageInc)
so yeah...
/close thread :D
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
