hey guys got my sard 280 installed a fw days ago, have been driving the car here and there and not running hwo it should or hwo it used to run, yous guys think it will need some kind of a retune or about 1hrs dyno time, the car also cut out for liek the 1st time today, i bought the pump and it seems to be in excellent condition but car isnt running how it was, maybe because its pumping more fuel and the injectors cant take it, yous guys htink it needs a retune because if it does its better to just upgrade the injectors and gett it retuned but i knwo thecar aint going nowhere as it still has the stock turbos and they are useless, what do yous guys think, upgrade the injectors because i dont have the cash for the turbos atm but in the next couple months can get a pair of gt2860r -5 or sumfin,
please guyas tell me what could be the problem or if the car just needs a retune and so if it does yous think upgrading the injectors would be a good idea?
cheers tony
https://www.sau.com.au/forums/topic/244566-got-my-sard-280-fuel-pump-installed/
Me either. If the old fuel pump was dying... then the new one should fix any problems...
Was the old pump even tested before being pulled out? If not, then you really cant say its got anything to do with the pump
Take it to a workshop.
what im trying to say is with my old pump it was running fine but after i got my new sard 280 pump installed it feels like it has lost a bit of power and running much more rich as i can easily smell the fuel, so now im guessing the car will probably need a hours dyno tune just to check the fuel mixtures but if it does need a retune i think its a good time to upgrade the injectors, right?
Well no-one will know, youve gotta check the AFR's. If the old tune was on a dying pump (which you really would hope wasnt the case, but sounds like it) then adding a new pump could make it super rich. Could even be a fuel reg dying and over fuel.
You really cant tell over the internet.
Injectors - Not if you have stock turbos??? Its wrong time.
Then you gotta tune it a 3rd time when you get the turbos, i fail to see the point in doing injectors now as there is no benefit what so ever if your only going to change it again and again. Wasted money on tunes
i put sard 720cc in mine the stock inj were 95% maxed out at 262rwkw on the stock r32 turbos on 13psi....
with the new pfc it was as easy as putting the new inj in loading up my old map and putting in to the lap top the new inj sard 720cc and it just loaded up my old map for the new 720cc inj
cost very little and no time at all to do!
but i would get some one to look at it first for your fuel pump problem..... im about to put my sard pump in and was told its just a straight bolt in and no need for a retune at all!!!
    • Dang I looked at this for so long until I realised it was for the inner rod. I was so confused. This looks like a great tool. Another injected plastic box for my collection. I for one am a torquer. I'm far too anxious and neurotic to not use the correct torques whenever I can. I do honestly feel like my wheels will fall off if I dont.
    • Not sure if you're being serious? I, and all the car people i know, ALWAYS use a torque wrench for wheel nuts. I assumed any car person, apart from tyre centre monkeys with rattle gun in hand, would do it properly.  Anyway, no further reply from me on this unless legit discussion from OP or his query so, over to you, knock yerself out.
    • I was wondering about this. I'll do some research.
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
