hey guys just wondering if i go through one of those electric carwashes in my car with the r34 gtr spoiler oon it do u think it will b ok?
the specific car wash i am going to is in cottesloe on stirling hwy its the one where u can also pay for them to do interior.
any advice will do thanks =]
https://www.sau.com.au/forums/topic/244593-car-wash/
as long as it's sealed it should be fine. I've taken mine through once before (it looked white with dust and I was desperate to get it clean :() and my spoiler was fine. It's a S2, which I put on myself. So you should be fine. My only issue was it took part of my SAUWA sticker off ;)
https://www.sau.com.au/forums/topic/244593-car-wash/#findComment-4257331
how much are you paying for this wash?i wash my own car since i dont trust anyone else with it.. also i get a greater feeling after i wash my own car[then parents spoil it by making me wash both of theirs =/ ]
Edited by R34P3R
https://www.sau.com.au/forums/topic/244593-car-wash/#findComment-4257492
i think the whole wash is around 27bux... it isnt like the BP fuel station ones it uses long peices of fabric instead and then they run around ure car and shammy it down for u and do the interior... it is really worth it... if they do a good job which these guys do i will try to find the name of it
https://www.sau.com.au/forums/topic/244593-car-wash/#findComment-4257510
Theres a "touchless" car wash in Malaga that works quite well. No chance of scratches.
Obviously it wont get off bugs on the front bar thats been cooked on their for a week but for a quick tidy up its fine. If im lazy, i use it on the way to work on a saturday morning :laugh:
https://www.sau.com.au/forums/topic/244593-car-wash/#findComment-4259132
just used the car wash and its all good.. they wash the car down first to get sand and everything of the car then they send it through the machine afterwards the shammy it 4 u so that there are no marks on the car
https://www.sau.com.au/forums/topic/244593-car-wash/#findComment-4259188
finished work and went straight to alexander drv carwash. washed my car and then wiped it down till there was no water spots... i drove to a park near my house and there are the yellow lights on the road so i parked my car under there and just staired at it, drooled about too... gotta love how a pearl white car looks under the orange lights...
dont tell my gf but i love my car more than her
https://www.sau.com.au/forums/topic/244593-car-wash/#findComment-4259874
HAHAHA
https://www.sau.com.au/forums/topic/244593-car-wash/#findComment-4260328
Looking isnt cheating... Right?
https://www.sau.com.au/forums/topic/244593-car-wash/#findComment-4262307
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
