Iam going GT30 really soon and i was wondering about a few things. Iam running a pretty heavy weight oil right now Greddy GR-1 10w-60, i get awesome oil pressure all day long (7.5 kpa revving high) and i was wondering if i should run a restrictor on the GT30 to prevent seals from getting blown.
Those of you who already run the turbo, what size oil lines did you run to the turbo? I was also planning on running a Tial 38mm external wastegate with VTA, will this suffice for my final goal of 15 psi?
Thanks
You sure its kpa? 7.5 kpa is 7.6 kg/cm2 and thats way too much pressure. Usual pressure for a road car is 3.5 to 4.0 kg/cm2. Even revving you shouldn't see 7.5 once the oil warms up, 5 maybe.
If you have a look at the bolt that clamps the banjo fitting to the block on the feed side, you will probably find that there is a restrictor in it already anyway.
There is a wastegate sizing help thread in the DIY section, a 38-42 sounds about right to me [i'm running the same turbo and using a 40mm at 16 psi, and I used the DIY thread and thats basically what it told me to use].
At say 3-4000 rpm cruising you should see 3.5-4.0 kg/cm2, thats normal or both my std gauge and greddy gauge and/or oil pump are stuffed and I know thats not true. If your going off the std gauge then it could be out........try installing an aftermarket gauge and see what it reads. I use 5w 50 synthetic, so it shouldn't read any different to your 10w 60 when its warm, maybe a small diff, but not enough to worry. Not saying your oil pressure is bad, but I wouldn't want it.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
