Car was purchased in April this year from Sydney and driven back to my home in Sippy Downs. Car has been garaged and well looked after. Serviced every 3,000km's with Motul Oil and Oil Filter. Car worked on by MW Performance on the Sunshine Coast.
PRICE DROP $21k - WILL TAKE ANY OFFER OVER 19,500 CASH IN HAND (with stock rims and no plates). Prepared to NEGOTIATE.
Would consider reducing price of car if performance mods were removed from vehicle. Happy to remove certain things to lower price.
Car has been run on BP ULTIMATE 98 Octane its entire life. -At present, car runs around 400-450km's per tank.
I welcome any questions and inspections on the car. You wont be dissapointed. Welcome to all reasonable O.N.O's - Reason for sale - Car is not used as often as i would like and is surplus to my needs. $22,000,Wont find a better price anywhere.
List of mods and prices of mods as follows:
Apexi AVC-R Boost Controller - $650
Apexi Power Intake Pod Filter - $89
Cold Air Induction Box - $150
Walbro 500hp 255Ltr Fuel Pump - $190
Whiteline Sway Bars, Front and Rear - $520
Cusco Rear Strut Brace - $210
Nismo Front Strut Brace - $100
Cusco Subframe Strut Brace - $150
Tien Super Street Coil Overs - $1680
Super Pro Subframe Bushes - $100
Hicas Lock Bar - $99
Full Tubro Back HKS Super Silent Exhaust with High Flow Cat - $1600
Splitfire Coil Packs - $529
Irridium Racing Plugs - $139
GREDDY timing belt
New Water Pump, Idler Bearings, Seals and pulleys. Includes new ancillary belts, 100,000km Service (done 30,000km's early) - $1,000+
Nismo Thermostat - $149
40mm Racing Radiator - $399
Cooling Pro Stealth Loop Kit Legal Intercooler - $550
XHP 18" Rims with 95% Federal Tyres - $1,900
Nismo front and Side Clear indicators - $110
B Pillar Strut Brace - Inside Car - $129
Alpine CD Player with 12" sub and 800watt amp - $600
Turbo Timer - Came with Car
Tinted Windows - $170
Nismo Gear Shifter. - $69
Link to images: http://www.carsales.com.au/used-cars/priva...amp;distance=25
PM OR CALL/TEXT on 0401637722
https://www.sau.com.au/forums/topic/244621-r34-sportsshow-car-medium-mods-21k/
  • 3 weeks later...
  • 4 months later...
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
