Does anyone know how or if the sat nav can be changed to aus maps?
try pm'ing chris rogers on this forum, he does the conversions on all the V35 skylines and stuff, if it uses the same software then it might be possible, he lives over east though but at least its a start
yeah chis will be able to do the job. These Y34's come with 3 different versions of dash screens and firmware, so cost will vary.
I attempted to fit a boost bleed valve to my Silver Y34 but couldnt notice any change in PSI. There is a vacuum hose and connection near the passenger headlight which i believe is the boost control solenoid. Remove it and plumb in your bleeder and it "should" work.
  • 4 weeks later...
Sourcing or repairing my black VIP's CVT is near impossible and extremely expensive, and of course it'll only fail again in time.
So my option was to convert to the 'normal' auto found in the gloria/cedric. I've had issues finding appropriate boxes/donor cars, so I have sourced a replacement engine & transmission.
This will be Australia's only RB25DET 4WD Y34 and possibly the worlds 1st VIP leather packed RB25DET. The RB25 cedric/gloria is not able to be imported as no one has the emissions report. As my car is already complied and has been registered, i can swap it over and have it engineered.
The 4WD setup will mean massive suspension changes on my car, but im hoping everything will bolt up between the 2 chassis. If i cant get it to work, then I'll remove the shafts and transfer case and make it RWD only.
The good news is someone will be able to buy my VQ30DET engine :D
Updates as they come to hand.
  • 3 weeks later...
been a few weeks and i've stripped the cut down and removed the dash and the engine with the subframe attached from the chassis. Next step is to do the same to my car. Already hit a snag though. The RB25DET has the transfer case, and my transmission tunnel doesnt have the nice big opening for it to fit in. Might have to chop it out and swap it over with mine. Another headache!
Anyone want a VQ30DET? Mine will be for sale. $2500 firm.
that would involve a custom tailshaft, different ECU and possibly loom, RWD sump and change of all the suspension components.
I'm going to keep the FWD components and just remove the front driveshaft, so when/if someone wants, they can get the rear actuator gear and ECU and make it 4WD.
Ah didn't realise it was auto. Good luck with it.
well, the wiring for the automatic shifter is done. The AC lines and water lines are done. The cluster is in and wired up. The ECU and body loom mods are done. Tailshaft has been swapped and new brakcets made. ABS sensors swapped. Now i need to work out how much of the tunnel needs modifying to fit the transfer case in, then its a bolt up, fluids and start.
More info when it comes to hand.
  • 3 weeks later...
Hey guys. Sorry its been ages since i have posted in here.
Have been a busy boy.
Have installed coilovers and put my wheels on my little boy.
Will prob do a Build Up Thread on my boy.
( most expensive car i have ever bought coilovers for). $4171.00 For JIC coilovers. I know its heaps and everyone could get cheaper but meh. They are in. It's sitting pretty and i love it.
Have had so many compliments on the thing.
Anywho once i get home from work and upload the pics to my comp i will start a build up thread.
K Thanx Bye.,
Brenton
My black cedric drives again! Just have to make an exhaust for it, swap the dif over from the donor cut and its complete.
Then i need to find some rims and rego. Its been a long haul and i dont recommend it to anyone, but at least it will be unique and easy to modify engine wise.
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
