Sick Of People Claiming Ghost Rwkw!
OK,
I'm sure youv’e all got a mate or no of somebody like this but what is it with dudes claiming massive power outputs on relatively stock cars. I’m not going to even look into the pshycology of it all but man it pissses me off.
So yesterday I was at a mates shop rewiring a hole heap of stuff and general maintenance and a unnamed SAU member came by in his 33. He was all like what are you putting down at the treds. I said Last dyno was 231RWKW. He was like yeah iv’e got 340rwkw with a stock turbo on 15psi with just a computer, fuel pump and exhaust. I mean I wanted to just get right into it but I thought f*ck it. What the point…. People like that aren’t worth it. I mean I have stock injectors and max them out at full tilt. Now how the hell to I get another 100kw down on those injectors. I have the HKS2535, bosch pump, surge tank, fuel reg, computer, FMIC, exhaust, Z32, Boost control, pod blah blah blah and I cannot squeeze that sorta power out…..
Am I missing something or are these people just living a pipe dream.
https://www.sau.com.au/forums/topic/244641-sick-of-people-claiming-ghost-rwkw/
  • Replies 71
OK,
I'm sure youv'e all got a mate or no of somebody like this but what is it with dudes claiming massive power outputs on relatively stock cars. I'm not going to even look into the pshycology of it all but man it pissses me off.
So yesterday I was at a mates shop rewiring a hole heap of stuff and general maintenance and a unnamed SAU member came by in his 33. He was all like what are you putting down at the treds. I said Last dyno was 231RWKW. He was like yeah iv'e got 340rwkw with a stock turbo on 15psi with just a computer, fuel pump and exhaust.
Was it a GTR?
I guess even if it was, that's pretty unbelievable at 15psi, or that's one hell of a ECU/EBC. Must be one of those dodgy dynos.
LOL these people are funny, you could almost say delusional.
Every so often one of these comments will be someone testing you to see if you can sort bullshit from fact, but 9 times out of 10 these people are just talkers that don't actually what they are talking about, or feel compelled to spout shit in order sound better than they are.
Just laugh it off, these people aren't worth the time of day.
hello
we have seen this in the past, but what we have also seen is "non comparable results"
that is - a car makes a given power in RWKW vs another car in RWKW and we assume both cars are same & dyno settings
the dyno sheeet says its RWKW, says its blah blah mode etc etc etc so the guy must have made 150rwkw surely - the sheet says so
so you compare this to your car and you make say 50rwkw and the other guy makes 150rwkw
what is a likely scenario is one or more of the following;
1) mangled dyno settings
- wrong mode set, wrong ramp rate, wrong car selected, mangled correction on the dyno
2) mangled dyno environment
- temp sensor in wrong spot, rollers mangled, fan mangled, different temperature (without correction)
3) different diff gears
- higher or lower
4) different ratios in the gearbox
- higher or lower
5) dynoed in different method
- shootout vs non shoutout
- engine dyno
- hub dyno
6) different fuel used
- could be 98, could be 100, could be 110, could be 130+
when i saw wrong ,as in when you compare A and B cars they arent the same
ie if you dyno a bog stockish GTST in 3rd gear you get around 180rwkw ish
we all know a GTST in 4th gear makes around 140rwkw - but the guy has more bragging rights cos he made more
is it right? probably not
but the paper says 180rwkw so he has to be correct
theres more to it than the dyno sheet - and the owner usually doesnt let on to all the of the mods, i mean, the might not remember all the mods etc?
at the end of the day, 340rwkw from a essentially stock gtst is laughable.
I have a 33 GTR with GTSS's running 19PSI , HKS racing chamber kit, Hks dumps, Tomei manifolds, mines stainless front pipe, no cat, kakimoto mega race catback, type B poncams, 700 sards (pump & AFR), EVC6 and d'jetro and only putting down 323KW (pretty sure on 4WD dyno but will check) so if he reckons 340rwkw on 15PSI, I want to live in his fantasy world, it sounds pleasant with an abundance of cheap HP
OK,
So yesterday I was at a mates shop rewiring a hole heap of stuff and general maintenance and a unnamed SAU member came by in his 33. He was all like what are you putting down at the treds. I said Last dyno was 231RWKW. He was like yeah iv'e got 340rwkw with a stock turbo on 15psi with just a computer, fuel pump and exhaust. I mean I wanted to just get right into it but I thought f*ck it. What the point…. People like that aren't worth it. I mean I have stock injectors and max them out at full tilt. Now how the hell to I get another 100kw down on those injectors. I have the HKS2535, bosch pump, surge tank, fuel reg, computer, FMIC, exhaust, Z32, Boost control, pod blah blah blah and I cannot squeeze that sorta power out…..
There is a company down there (Melbourne) that has obtained some very 'excited' results from their dyno. They even had the stupidity to start a thread on here to beat their own chest...which horribly backfired and left them with zero credibility.
It may have been dyno'd there....lol
Edited by DiRTgarage
LOL!
Which place was that?
    • Welcome. Dont let anyone dissuade you from your dreams. If you want a gtr, keep sabing and you will eventually get one. I feel like if I had have bought stocks, those companies would have gone bust and I would have lost my money.  There's a gamble in everything we buy. I've had good times and bad. But... I've also met my absolute best friend through this network and can't imagine life without them(more like a brother). Keep in mind, some specific mods will change as technology gets better. If you feel like general chat, there's always the wasteland.....
    • Those are some very cutesy barriers! Is that common?
    • Saw this abandoned Honda Fit in a carpark that was getting repaved... they just 'cut around it' and continued with the job! There's a number of reasons why the car could have been abandoned, but as for the construction company, legally they don't have permission to move the car from the owner (who has moved on and can't be contacted) so all they can do it just leave it there with enough space around it so it won't get damaged.
    • You’ll want to have the block drilled and tapped to suit 1/2in head studs and the head for the same. How much power do you intend to make?
    • Sorry for resurrecting an oldish thread Not much has happened in the past year since the last update. The car did another 1000 miles or so and failed the MOT for the first time in October (failed on tyres which had been advised for a couple of years) In October the car got put up for sale and was removed in November due to no interest, being so close to christmas it was to be expected. The roads were dry in February so I decided to tax it early and get the new tyres fitted.   Fast forward to April, I got someone in to give the car a good clean after sitting for the winter.                                 The car got re-advertised and today (Saturday 3rd May) the car sold. The new owner is planning a GTR conversion at some point and a respray in the same pearl white. It's bitter sweet, it's a shame to have the car sit there for half the year and then only do 1000 miles. The kids are growing too quick and space in the back is getting limited. It's been a great 6.5 years of ownership
