Hey Dave,
You will need to retain your gtst brake lines and make sure you have adequate clearence for your rims. Other then that they will bolt on.
ps. if you can get two sets pm me im keen on an upgrade.
Cheers,
Johno
Edit: the stone guards need to be removed or modified to suit a larger rotor other wise the rotors will foul on them.
Hey Dave,
Cheers,
Johno
Awesome, thanks Johno.
PM sent.
probably will fit OK....the hub where it bolts up is the same so the caliper and disc should fit up OK. Brake lines may need to replaced depending on the exact setup.
And of course wheel diameter, offset and design are the biggest issue....
