Bribie Island & Scc08
wilorichie
 Share
Hey guys,
I have a friend from Bribie - His skyline isnt going to be ready for SCC08 :D
He really wants to come! Would anyone here be keen to give him a lift to the meeting point and a lift back at the end of the day? He lives at Bribie Pines
It's a 3 hour trip for me and I unfortunatley dont have the time to spend 6 hours driving him to and from.
Anyways, if you can give him a lift, I'll take him off your shoulders at the Meeting point until the end of the day.
Obviously I don't want you taking a detor to pick him up... Looking for anyone close by to him - he would really appreciate being able to come to the SCC08.
If you can do this for him, please give me a pm or reply to this thread.
Thanks in advance
Thanks so much for your generosity mate!
I'v told him to give you a call this afternoon. Hopefully I told him the correct name - Jim
Anyways, I'll leave it up to him to organise it with you, I just wanted to help him get started (hes a bit of a shy guy, I havnt seen him for about 4 years though - best friend childhood friends hehe).
Once again - thank you for your kindness.
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
