just goes to show how big a car the R35 is... I remember first seeing one at the Melb motor show noting its easily as big as a 599... both absolutely massive for coupes! and people carry on about the size of 33's hehe;)
+1 for not caring how it looks at the track, 3sec's is the biggest time improvement from a single mod by far... and cheaper in the long run!
Should be way more than 3s. If it'll pull 3s on a 1:40 lap, simple math would say you'd see around 12s over 7:26.
However, since R-Comps also tend to have a greater heat capacity than regular street tyres, they're less likely to go greasy at the end of that period so the driver can attack harder for longer, meaning you might see even bigger gains.
  • 4 weeks later...
  • 3 months later...
Hello :) First post here. The car in question is mine, and they do indeed look like poop with the huge wheel gap.
But as others have said, 3 seconds is 3 seconds, especially on a 1:40 roadcourse.
The 18" setup proved to be a worthy track mod, but this year my new setup is Volk RE30 19x10 +30 and 19x11 +25 with Hoosier R6 295/315
I changed to the 19" setup not for looks but for a better tire setup. The Michelin Sport cups worked quite well but proved to have more understeer than I care for. With the new Hoosier 295 and 315 on the 19" RE30s should help reduce a lot of the understeer I was having and I'm very excited to try the new setup in a few weeks at my local roadcourse.
I'll be sure to post my results here, I am from the US btw (damn yanks) but love the australian car scene and your roadcourses too! :blink:
And yes, the Rossi helmet was good for 1 second faster laps of course. Heh, gotta love it. Good eye to whoever noticed my helmet. I have 6 of his helmets and many many Rossi minichamps (all of them that have come out to date, to be exact). You could say I'm a big fan, but of course Stoner is an AMAZING rider as well.
Take care mates, and I'll try my best to remember to come back and post more pics and results with my 19" RE30 setup.
Billy
    • Maybe but doubt it, when I jacked it up it was creaking in the j arm again. The inners are all good, I inspected them. Remember that also it did fix the problem but temporarily.
    • Could be the other bushes. The inners.
    • Once you lose the adjustable bushes, you have almost no adjustment at the front for anything that matters. You can only wind so master caster at the front, and ~7° is fine. You won't have choice of front camber. If you only have rear camber arms (ie, do not also have adjustable upper tension arms), you shouldn't change their length very much, because you will introduce bump steer. And, you will struggle to find a workshop that will be capable of doing all the adjustment work necessary to simultaneously achieve a decent rear camber number, get the toe right, and minimise bump steer. I would guess there's probably 8 hours of work there. So, stockish rear camber is fine. Although, keep in mind, that stock camber, by number value, does not mean stock arm length when the car is lowered. You will need to lengthen the RUCA to get back to stockish values and that will require the tension arm to be lengthened a little also. Without any other guidance, any change made to the RUCA should have the 2/3 of the same change made on the tension arm. But that is only a rough rule of thumb and the relationship might not remain linear across a wide range of adjustments. And it might not also be as close to minimum bump steer as you could achieve if you did the bump steer measurement and adjustment properly.
    • Well it does have a motor with the same DNA as an Accord V6 motor. The J30A is a successor to the Tiger rice cooker C32A motor found in those cars.
    • FD RX7 I would probably marry if legal R32 GTR is toughest NSX looks like it's made from leftover Prelude and Accord bits
