just goes to show how big a car the R35 is... I remember first seeing one at the Melb motor show noting its easily as big as a 599... both absolutely massive for coupes! and people carry on about the size of 33's hehe;)
+1 for not caring how it looks at the track, 3sec's is the biggest time improvement from a single mod by far... and cheaper in the long run!
Should be way more than 3s. If it'll pull 3s on a 1:40 lap, simple math would say you'd see around 12s over 7:26.
However, since R-Comps also tend to have a greater heat capacity than regular street tyres, they're less likely to go greasy at the end of that period so the driver can attack harder for longer, meaning you might see even bigger gains.
  • 4 weeks later...
  • 3 months later...
Hello :) First post here. The car in question is mine, and they do indeed look like poop with the huge wheel gap.
But as others have said, 3 seconds is 3 seconds, especially on a 1:40 roadcourse.
The 18" setup proved to be a worthy track mod, but this year my new setup is Volk RE30 19x10 +30 and 19x11 +25 with Hoosier R6 295/315
I changed to the 19" setup not for looks but for a better tire setup. The Michelin Sport cups worked quite well but proved to have more understeer than I care for. With the new Hoosier 295 and 315 on the 19" RE30s should help reduce a lot of the understeer I was having and I'm very excited to try the new setup in a few weeks at my local roadcourse.
I'll be sure to post my results here, I am from the US btw (damn yanks) but love the australian car scene and your roadcourses too! :blink:
And yes, the Rossi helmet was good for 1 second faster laps of course. Heh, gotta love it. Good eye to whoever noticed my helmet. I have 6 of his helmets and many many Rossi minichamps (all of them that have come out to date, to be exact). You could say I'm a big fan, but of course Stoner is an AMAZING rider as well.
Take care mates, and I'll try my best to remember to come back and post more pics and results with my 19" RE30 setup.
Billy
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
    • OK, well, in that case, the suspension specialist is either a moron, or you aren't understanding what he was trying to tell you. Nismo arms are not really different than stock arms. Both are fixed geometry. I don't know if the Nismo ones are a little shorter than the stockers (or perhaps even a little longer) or the same length, but....if you swap from stock to Nismo, whatever happens to one side will happen to the other side. It will not cause it to steer left or right. That is unless you have adjustable bushes in your stockers, and they happen to be adjusted to dial out some bent chassis shenanigans. But, if that were the case, you'd just put adjustables in the Nismo arms anyway, because Nismo arms are essentially just expensive stock arms. And doing a wheel alignment is just a weekly thing in my world. I have had the suspension apart so many times this year that I've lost count and just about worn out a torque wrench. I'm out in the shed right now cutting up some alloy section and making bases for my new stringline setup. Got to make new swivel plates next, then I'm good to do toe properly, as well as camber and bump steer.
    • Yeah, nah. Not a thing. The gasket between the top of the plenum and the runners is far more likely to blow out when it gets old, and not really at ~14 psi. These things have been run to double that for 30 years without that being a common thing.
    • I plan to pull the intake manifold off and check the gaskets, i read that the block to manifold gasket can blow over 14psi and when i picked up the car it was set to 1.2bar on the controller. Send the injectors out for cleaning. Ill also pull the cam covers off and do an inspection, check some valve lash. Someone also said that the timing belt can rub or vibrate against the belt cover and make that sound. Definitely need to get an AFR gauge on it, if it was lean idling im sure it wont be happy
