Originally posted by R33man
I was recently quoted $4000 for supply and fit (including dyno tune) of a Power FC computer and boost controller.  Is this a good price or should i look elsewhere.  :)
:bahaha: can u say RIP OFF??
U can buy one new for $1400 with hand controller, to install takes about 10 mins if u know how to use a screw driver and socket set. Proper tune depending on mods you got about 2 hrs.
All up i think u are paying around $2300 more than u should.
https://www.sau.com.au/forums/topic/24467-power-fc-cost/#findComment-523164
Originally posted by Ronin 09
look out guys, customs are getting smart. The last 2 packages from greenline i've received have been taxed, and they've somehow got the exact cost of the items as per greenline's site...
How much tax did u pay on the parts??
Customs must be reading the forums to now.
https://www.sau.com.au/forums/topic/24467-power-fc-cost/#findComment-524328
Originally posted by hungry6
mine is costing me a fair bit more to tunecause i'm looking for the every last horses in the motor , including the one hiding behing the trees.
One word : DETONATION.
If you try and extract evey last pony, as soon as the air temp changes, or you get a slightly off batch of fuel etc, your check engine light starts flashing away at you, ignore it and do a rebuild.
Its a real pain (talking from experience). If you go for a more conservative tune, it is more likely to give you a longer, hassell free life.
0.02
https://www.sau.com.au/forums/topic/24467-power-fc-cost/#findComment-524718
Steve...of course detonation and exhaust temp would be taken into consideration. In fact a lot time is usually spent tuning at the track (if the pockets are deep) where temp is hot and car is being pushed hard...would have thought you had done that with your car too.
P.S....why would you ignore the engine light flashing at you?
https://www.sau.com.au/forums/topic/24467-power-fc-cost/#findComment-525269
4 Doorz, the post just set off alarm bells, so injecting a word of caution. Every last pony insights visions of max hp on a dyno - to me anyways. I had someone do a 'get every pony possible' tune, and it wasnt long before I took it somewhere else and got a retune.
I completely agree with you, WRT a good tune. My car doesnt get track tuned, but it does get a good workout on the street. And yes it does cost extra, but well worth it IMHO.
Check engine light - some people dont keep an eye on their check engine light, and usually pay the price.
https://www.sau.com.au/forums/topic/24467-power-fc-cost/#findComment-525658
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
