Originally posted by R33man
I was recently quoted $4000 for supply and fit (including dyno tune) of a Power FC computer and boost controller.  Is this a good price or should i look elsewhere.  :)
:bahaha: can u say RIP OFF??
U can buy one new for $1400 with hand controller, to install takes about 10 mins if u know how to use a screw driver and socket set. Proper tune depending on mods you got about 2 hrs.
All up i think u are paying around $2300 more than u should.
https://www.sau.com.au/forums/topic/24467-power-fc-cost/#findComment-523164
Originally posted by Ronin 09
look out guys, customs are getting smart. The last 2 packages from greenline i've received have been taxed, and they've somehow got the exact cost of the items as per greenline's site...
How much tax did u pay on the parts??
Customs must be reading the forums to now.
https://www.sau.com.au/forums/topic/24467-power-fc-cost/#findComment-524328
Originally posted by hungry6
mine is costing me a fair bit more to tunecause i'm looking for the every last horses in the motor , including the one hiding behing the trees.
One word : DETONATION.
If you try and extract evey last pony, as soon as the air temp changes, or you get a slightly off batch of fuel etc, your check engine light starts flashing away at you, ignore it and do a rebuild.
Its a real pain (talking from experience). If you go for a more conservative tune, it is more likely to give you a longer, hassell free life.
0.02
https://www.sau.com.au/forums/topic/24467-power-fc-cost/#findComment-524718
Steve...of course detonation and exhaust temp would be taken into consideration. In fact a lot time is usually spent tuning at the track (if the pockets are deep) where temp is hot and car is being pushed hard...would have thought you had done that with your car too.
P.S....why would you ignore the engine light flashing at you?
https://www.sau.com.au/forums/topic/24467-power-fc-cost/#findComment-525269
4 Doorz, the post just set off alarm bells, so injecting a word of caution. Every last pony insights visions of max hp on a dyno - to me anyways. I had someone do a 'get every pony possible' tune, and it wasnt long before I took it somewhere else and got a retune.
I completely agree with you, WRT a good tune. My car doesnt get track tuned, but it does get a good workout on the street. And yes it does cost extra, but well worth it IMHO.
Check engine light - some people dont keep an eye on their check engine light, and usually pay the price.
https://www.sau.com.au/forums/topic/24467-power-fc-cost/#findComment-525658
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
