Need The Number For The Guys That Ran Jds In Hobart
Hey all, Just wondering if anyone can let me know how I can find the guys that ran JDS in hobart, from what i understand they have set up shop by themselves somewhere in Derwent Park. I would appreciate it if someone could tell me where they are or even a phone number would be great.
Thanks :P
Medium Dave. we haven’t got a place as of yet. but yes we are wanting to get out to Derwent park
Josh an My self are continuing ON, but NOT under JDS. We are currently toying with a few names, so if any one has any Good Idea’s let us know.
We want to continue the service’s JDS provided but at a better PRICE
WE still;
IMPORT cars
New Parts
Second Hand
Motors
Half Cuts
….. List goes on
So every one please get behind Josh an my self as we are only here to help you guys an Girls out
Tim
0433 127 001
( email set soon – stay tuned )
Josh
0433 958 971
Spread the word.. =)
WE still;
IMPORT cars
New Parts
Second Hand
Motors
Half Cuts
….. List goes on
Tim
0433 127 001
Josh
0433 958 971
Id suggest not doing that :wave:
is this spg
No SPG is a different group/business >_<
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
