Need The Number For The Guys That Ran Jds In Hobart
Hey all, Just wondering if anyone can let me know how I can find the guys that ran JDS in hobart, from what i understand they have set up shop by themselves somewhere in Derwent Park. I would appreciate it if someone could tell me where they are or even a phone number would be great.
Thanks :P
Medium Dave. we haven’t got a place as of yet. but yes we are wanting to get out to Derwent park
Josh an My self are continuing ON, but NOT under JDS. We are currently toying with a few names, so if any one has any Good Idea’s let us know.
We want to continue the service’s JDS provided but at a better PRICE
WE still;
IMPORT cars
New Parts
Second Hand
Motors
Half Cuts
….. List goes on
So every one please get behind Josh an my self as we are only here to help you guys an Girls out
Tim
0433 127 001
( email set soon – stay tuned )
Josh
0433 958 971
Spread the word.. =)
WE still;
IMPORT cars
New Parts
Second Hand
Motors
Half Cuts
….. List goes on
Tim
0433 127 001
Josh
0433 958 971
Id suggest not doing that :wave:
is this spg
No SPG is a different group/business >_<
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
