Thanks for organising the day Nugzy awsome set up Ash has there. Also nice to see he spent the time to point out things in the tune that could be better fuel economy wise etc.......And whats up with 130 on the Knock reading (PFC) in my bus glad he pointed that out to me or i could be up for a new motor sooner than i was hoping. Be keeping off the loud pedal until thats sorted me thinks.
what an amazing set up ash has down there, definatly the cleanest most well presented and organised workshop ive seen, i'll be definatly seeing him soon for a few things for the gtr.
good on nugz and the 31 club organising it, shame more people didnt turn out
thanks for coming guys...was a good day..even if we only had 9 cars on the dyno....just shows how badly my car needs work b4 i detonate it.....oh wells....
RESULTS..
1.GTSsilo_tys (R31 gts1) worked rb30et.. 250.4kw
2.RB25DETS2 (sexyas R33) mild rb25det..246.3kw
3.ADEL_GTSX(vt ss ute) gen3, cat back..202.00kw
4.Joel...(vz ss ute) gen4 6.0....195.7kw
5.nugzy!!!(r31 TI) low comp rb30e-t auto...171.3kw
6.vanders(R31 exec) rb20det, fmic..etc...146.5kw
7.mrs nugzy (AU fairmont) 5.0 v8..extractors...113.9kw
8.pimpintaters.(R31 silo) rb30. pod, zorst...92.1kw
9.charged (gf's R31 lol )rb30. bit of a zorst. no airbox...88.5kw
wouldve been awesome to see the forcefed silvia belt out 500kw...but the engine became a sad panda and decided to cut itself a new breather hole in the block friday night.....dorift_pig has vowed to be back with a crazier motor next time....and there WILL be a next time.....thanks again guys for rocking up :whoops::):yucky:
Yep +1 to that!! Very clean workshop. Was good to see a few cars out there. Will be giving them a call to see what they can do for the GTR!
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
