errr stop scaring the guy lol its nothing compared to my encounter the other night i was with a mate on chap st going to eat and a spider the size of my hand walked across my windscreen.. its amazing how power windows wont work when your shitting your self lol
we ended up killing it but let this be a lesson to everyone when your car is off the Rd before it comes back on the RD spray it with mortien or something because they live in your door jams happend to my mate to he almost had an accident lol
Yes, some of those nursery rhymes are nearly as bad as what you see in the Tiger Balm Gardens in Hong Kong or Singapore.
Perhaps parents read them with a smile to their little children so that they don't run away when they're taken to the shops.
Like, "Don't run away, or the spider will get you!" lol
Now if I were a spider, a cosy spot next to the door seal doesn't sound like a bad idea! Might even get the 'travel bug' er....
SICK!!!
This sir is a horrific topic. I could not get in the car at all should it be dead or alive...however dont they shed their skins? could the bigger newer improved model be waiting to launch its attack when you least suspect it?
HAHAHAHAHAHAAAHAHAHAHHAHAAA!!!
i used to have a spider that lived behind my side mirror. it used to always make a web accross the mirror. then he would make one from the antenna down to the bonnet, then another web on the left hand side mirror. then one day i noticed a web accross the aircon vent inside my car. i was scared he would attack me while i was driving.
then oneday i saw him dead near the gear stick. and all the webs stopped. :P
Or so you think! he killed another spider or shed his skin hes just waiting for the perfect time to attack! just wait
Ring a ring a rosey a pocket full of possies a tissue a tissue all fall down, This was a poem about the killer flu which killed half of europe.
yes although back in the old days, the mannerism was more formal, but i found they were more sinical....
this thread makes me shiver..
from my experiences, spiders seem to be fond of living in VN side mirrors, and lodge themselves far enough back that even a high pressure hose sprayed right in there fails to dislodge them. Touch wood, i've not seen any in my Skyline but it never gets parked under trees!
Fuse boxes also seem to be a nice home for them, have you had a look lately?
    • No need to replace the cover if it is still intact (not worn through). It would be worth checking the balancer for matching marks on the rear, but I'd assume the balancer was loose at some stage. The cam timing marks look fine, once you put the new belt on you can only be right or a full tooth out
    • Disconnecting rods! must have been an unpleasant surprise...
    • So been ocd with timing mark but checked from few angle and seems both cam are on and crank is matching as well to the slot on sump and crank pully   i noticed crankshaft cover has been robbed as per attached pic. Any ideas why? Could my balancer or harmonic be on its way out? should I replace the cover? https://ibb.co/ZR1JFYRR
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
