Apparently Croydon racing developemts have just released a New brand NITO. i have never heard of these parts and being a new Brand name Thought i should ask the question.
Is anyone using any NITO internal patrs on their SR/RB or have you heard of this brand?
some parts i looked at for the rb;
NITO, billet not forged rods (i beam) with arp bolts $1390
NITO, Oil pump Special (Strengthened gearing) $1390
just parts no labour, if you look at the tomei oil pumps there something like $2200 cause the Aussie $.
so i thought these parts arent priced to badly??
Well, their rods are off the price. The oil pump is a bit more reasonable, although JUN is close to that money
Hopefully they do a stroker kit at a decent rate
agreed on the rods, should still be able to pick up a jun pump cheaper than there nitto from the right people.
anyone know if they are an alloy billet rod or 4340 billet rod tho?
Edited by Cartman
i think they were saying it was aircarft billet materials or something.
I would be interested to see how Nitto Rods would compare against Autech, especially with the cost difference.
I-Beam Nitto's for RB for $1390, or I-Beam Autech Rods & ARP Bolts for $799.........
  • 1 month later...
i was are crd today and ordered a nitto oil pump they are based of the jun pump they showed me all the nitto products they have and you can clearly see why they changed to useing them they also have a 3.2l strokerkit on the way for the rb30 in the next few months wish i had the dollars for one
How much for the 3.2L?
i have used thier gear in SR's for a while as many customers supply thier own internal kits, the rods are ust the same as all the other taiwanse gear.
im thinking about going with the Nitto oil pump my engine builder recommended. he says the way they were tested for strength was they were put up against other oil pumps of the same drive type (std/n1 etc) and revved to 14,000rpm. he told me the other ones barely made it past 8-9000rpm where the Nitto was going strong after its time at 14,000rpm.
he also showed me a Nitto crank shaft which weighed at least 1.5 times more than a standard one and is intended to rev to 9000rpm. it was a chunky piece of kit though.
you would be better of getting a decent harmonic balancer to soak up the oil pump smashing vibrations from your rb30 crank.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
