Hi Terry,
Welcome to SAU Forums...
I've been using a Blitz FATT-DC without any dramas. I've pulled down some documentation off the net as to what else it does, but I've never experimented with it yet.
Regards,
Terry
https://www.sau.com.au/forums/topic/244753-turbo-timer/#findComment-4260034
I'm using GReddy, it has heaps of features but is a bit of a pain to use (just trying to push 2 or 3 buttons at exactly the same time), I can't seem to calibrate it right atm, but when working properly is pretty good.
Has several different timer settings including a calculating one which monitors how hard you driving and recommends a cool down time, also has lap timer, 0-100kph 0-200kph time, 1/8mile and 1/4mile timer, voltage meter, speedo, RPM display, not sure what else but heaps more than I ever used.
oh, And Welcome to the forum, I'm sure you will find all your answers. Do a search and you will find heaps.
https://www.sau.com.au/forums/topic/244753-turbo-timer/#findComment-4260061
I've got a turbo timer integrated into my car alarm. Insurance legal, which is a plus.
It's not "intelligent" and based on water temps, loads etc unlike standalone units. If you drive for less than 3 mins it won't turn on. Otherwise, it just idles the car for a minute.
https://www.sau.com.au/forums/topic/244753-turbo-timer/#findComment-4260157
waste of effort and time..... all they do is do a few measurements and keep the car on for a little while to reduce the pressure or heat or something for the turbo,,,,, yes they are good to have for the turbo but your not meant to thrash the car and then turn it straight off anyway.... your an idiot if you do that, thats why most events have a warm down lap, if your cruising around looking for a car spot you dont need a turbo timer, if you live anywhere other than a highway or a main road you won't need one, and on most cars if you have a tt you have to wait for it to turn off just so you can lock the car and turn the alarm/imobiliser on so your better off just sitting in the car for a minute before you turn the ignition off.
If i was looking for a fast car to steal, i'd look for one with a turbo timer i can see from the outside of the car, think about it, all the wires for hot wireing a car are exposed so you dont even need to damage the steering column or waste time trying to find the wires.... most TT's don't allow alarms to be activated untill the TT has turned off so more chance of someone successfully getting away with your car, they are illegal for the very reason that some faulty ones stay idleing in undercover car parks and never turn off untill you return to the car and disconnect it, and good luck getting insurance from a ride off when they recover the car and say "if the TT wasn't there the car wouldn't have been stolen because the person set the alarm and immobiliser before the TT turned off".
if your buying it for time measurements your going to put other things in the car, like ecu's and guages, boost controllers and so forth, most of these products integrate timing in them aswell now, and allot more accurate.
I bought an insurance aproved alarm/imobiliser with a built in TT, no fuss, no hassel, never forget to arm it because it arms itself if you forget, it arms even if the TT is still on, its legal.
and if you are buying it to do both measurements and to use as a traditional TT don't forget it will be visible for you to see it while your driving, so car theives and coppers can see it aswell...
spend alittle extra, an imobilser and a TT seperate will cost you around $200 right???? up to around $400 if you get it installed at a car audio place???? $600 i got mine prfesionally installed at rretail price and i have piece of mind that i have one less thing to get defected and hasseld about, and i have more chance of comming back to the car park and being able to drive home that night, and if it does still get flogged there is no reason for insurance to reject the claim.
https://www.sau.com.au/forums/topic/244753-turbo-timer/#findComment-4261254
i have a ye olde HKS timer... non intelligent just keeps the car on for 30 sec when i get out... its great for me as i NEVER remember to put my windows up.
came with teh car...
my alarm arms while the car is still runing
https://www.sau.com.au/forums/topic/244753-turbo-timer/#findComment-4263981
Just get any turbo timer, they all do the same thing. Most of the features on turbo timers are just a load of wank anyway...
Agreed. +1 for Apexi and +1 for Blitz fatt. Turbo timers should be set and forget. No need to play with them.
https://www.sau.com.au/forums/topic/244753-turbo-timer/#findComment-4264104
1+ for waste of space. Absolutley no need for one. Take it easy for the last few kms. IF your hammering it until you turn the car off what about your gearbox, diff, engine oil and whatever else temps you have.
https://www.sau.com.au/forums/topic/244753-turbo-timer/#findComment-4264155
Pretty much any turbo timer and be installed to allow the alarm to arm while the car is on. All depends on how good the alarm installer is. And while inbuilt TT are good and convienent, most of them cant be changed from the basic 1 min cool down.
Yes, its good to take the last few km's easy before turning off your car, but giving it a few more mins extra cool down is always good. Hence why TT's are such a good things to have.
Not sure about your insurance company, but i have told mine what alarm i have and that i have a external TT and they said its fine, and insured me for it.
https://www.sau.com.au/forums/topic/244753-turbo-timer/#findComment-4264346
Waste of space? How big are they ?
Cost u only 100 (at most... second hand can be sourced at 50 bucks) bucks to get one. Installation for it is cheap and can be intergrated with your alarm.
So the question is why not? They certainly dont do any harm and any cooldown time the car gets extra is defiently a good thing.
https://www.sau.com.au/forums/topic/244753-turbo-timer/#findComment-4264353
Got the same one as Emsta, the Greddy. Has bettery voltage, intelligent timing, 0-100 times, Lap timing, all this extra shit you never use. haha
Mine is hooked up so i can alarm the car whilst the engine is running. People look at you wierd when you walk away from a running car.
https://www.sau.com.au/forums/topic/244753-turbo-timer/#findComment-4264355
  • 4 weeks later...
    • Oh and my rear arms may need some attention too.
    • Bushings are almost done. Check the date stamp 馃槀 these are likely the original bushings with 27 years and 243ks on them.     Was too dark to get a pic of the worst one.
    • Porous blocks are a known issue on something like a Porsche M96, it's not really something I've ever heard of on an RB26. It's possible what people thought was a "porous block" was really a cracked block that they just didn't spot the crack on.
    • This is a controversial subject really, the whole power vs fun thing I mean And this is the main reason I got back into a MX5 Of the last few notable daily cars I've owned whilst I have frequented SAU R33 GTS-t: fun, but because I'm a idiot I modified well past a reliable fun car and ended up hating it, although that was my fault because I tried to have a daily cruiser and race car all in one, the family called it the sometimes car, because sometimes it was working, sometimes it was broken, gladly sold it NB MX5: brilliant car, thrashed the Bejebus out of it, but, again, was stupid and deleted the air con, power steering and stripped the interior out, whilst still fun, and reliable, and super cheap on consumables, it was not a fun place to be going on long cruises, I did love it, but basically every family member hated going anywhere in it, sadly sold it 2015 WRX STI: soulless thing that looked like your average Kia sedan and had that horrible boxer engine with glass ringlands, the family did like it though, that thing was one of my stupidest purchases and I still regret it 2017 Toyota 86: 馃槳 if I didn't crash it, I would probably still have it, it was a fun little thing, even with that horrible boxer engine, the family did like it, the only reason I didn't get another 86, or, BRZ was the boxer engine, I should have learnt after owning the STI, but I'm a idiot VX SS: great cruiser, fits the whole family, and was fast as.....in a straight line, but a big fat thing, so no enjoyment throwing it around corners, the family was unimpressed with the whole boganness of if, but they did admit it was a comfy place to sit on long cruises As for the NC, I feel it is perfect for what I want, or need out of of a car, whether I'm cruising the Hwy, back roads, twisties or peak hour traffic, the Mrs doesn't mind driving it either, or cruising in it as well, although she does bump her head of the roof nearly every time she gets in, which is farking hilarious, and the kids love taking it for a thrash as well So basically, I've had constantly more fun, and way less headache and heartache, both on the track and on the street, in low powered cars,  go figure.....LOL One thing though, the Mrs has stated that the cams have made the exhaust sound much louder, which they have, but it doesn't bother me, in fact, I actually like it, but, to negate any future comments from the Minister for War and Finances I may look at some changes to the rear muffler set-up to drop the volume down a tad to appease her when we are out and about in it
    • You will need to extend the turbo inlet pipe somehow, which could/might be done with silicone/rubber pipe, but might need steelwork, depending on your intake. And you will need to change the pipework on the outlet in teh same way, but this is more likely to need steelwork.
