hey guys i have decided to sell my s15, i have spent ALOT on this car in the past 2 months with the following parts brand new out of the box from japan and have done abround 10 kms. The car is in a1 condition always serviced and owned by a lady owner in japan.
Nissan s15
6 speed
100 xxx kms
SUNROOF
all factory options
6 months rego
- ORC single plate clutch and lightened fly wheel
- GTC's face 2 18x10 18x9 in top secret gold face 2 with carbon center caps/ nuts etc ( same offsets as the Lozs promo car.)
- Exhaust technology dump pipe,front pipe
- Exhaust technology stainless system with jun BL muffler and custom flutes
- Nismo rear cradel options
- SILKROAD Rma8 coil overs
- Origin L.E.D rear tail lights
-VERTEX sides and rear ( can arrange front bar )
-Custom FMIC and Piping
-Trust airnix filter kit
-Greddy profect B II boost controller
- Greddy turbo timer
-Carbon din panel
- New Brake pads
- Kenwood cd/mp3 player
- clarion splits
-Trust shifter
-Custom candy apple rocker cover
+ many more im sure that i have not listed.[/size]
PLEASE KEEP YOUR COMMENTS TO YOUR SELF AS I DONT NEED TIME WASTERS!
Rear guards will need a flair and front needs a tad more camber with a slight roll which will cost around $80 a corner for the front and a bit more for the rear
CAR CAN BE SOLD WITH LESS MODS AND THE WHEELS OF YOUR CHOICE : SSRS POLISHED IN 18INCH OR STOCK WITH SALE PRICE ADJUSTED
$27500 with wheels
$23.500 with stock wheels and less modifications
pm me and ill get back to you as soon as i can.
kind regards
kane
0423697701
i have got alot of pms regarding swaps with there r32 r33 gtrs silvias etc+cash. please im after cash sale as i have another car on the way from japan.
cheers guys!
    • That's f**ked up. I'd guess it's more likely that you have an entire S13 subframe in there. Does it still have HICAS mounting points? Seeing as it is quite possible that yours is the only such converted car in the world, you'll probably struggle to find someone who can tell you from direct experience. 'Twere I you, I'd be looking for 4 stud Skyline rear brakes and convert back. At a minimum. Preferably go find all the stuff you need to put it back to 5 stud (assuming you're happy to change wheels) and upgrade to some decent brakes. You don't even need much stock stuff. Don't need calipers or rotors, as you can go fully aftermarket. Just needs hubs and the other bits and bobs that are different to what you have now.
    • The engine has nothing to do with it. The physical space behind the headlight is the limiting factor. And the height. The height of the NS70 is the same as stock. So the clamp bar across the top goes on nice. The battery tray is big enough for it to sit on. The X is for extra capacity - it has even more lead in it than the non-X NS70. Heavy f**ker. But it's not a track car, so I will suffer a couple of extra kg. In the case of the R34, maybe the physical space there is not as deep (forward-backward, not up down). Hence why they say the 60 is the biggest. But I would never trust a catalogue to tell me what will fit. I have the car. I have the existing battery. I have the tape measure. I have the dimensions of all the available batteries. I find the biggest box that will go in. (With the right terminals in the right places, of course).
    • Hello! I have been having a hard time finding the answer to this question… I have a R32 GTS-T Sedan than has been 4 lug swapped using S13 hubs, rotors, and brakes. The front has also been converted to S13 suspension.    When the swap was completed, the handbrake cables were never hooked up, as the S13 rear calipers are the “handbrake”, and not the typical drum on rotor that the R chassis are. Does anyone know handbrake cables that will work for this conversion? I’d like to not use a hydraulic handbrake and stick with the traditional cable style. My original thoughts were to go with S14 cables and try to make them work, since I’m pretty sure S13 cables will be too short.    Any help would be appreciated!
    • I did some research, considering you have a neo engine, how is that battery compatible? I checked centuries website and super cheap and says it's not compatible. Only this full size one is. https://www.centurybatteries.com.au/products/ns60-mf
    • No, lets be honest here. I went to Winton and did a track day, for all the mods and V8 power and craziness I posted up a time that a K24 stock motor Honda Accord can do on the same tyres (narrower, too) 250kw and learning how to drive the f**kin thing is the sweet spot.
