Hi
I am running an ALPINE MRP M500 monoblock amp which is rated at '500W RMS x 1 (2 ohm @ 14.4V) and/or 300W RMS x 1 (4 ohm @ 14.4V)'
It's going to be powering a 12" ALPINE TYPE-S sub which is rated at 'Peak Power Handling: 900 Watts and/or RMS Power Handling: 300 Watts / Power Range: 50 - 300 Watts'
I'm confused about 2ohm/4ohm and all this tech stuff so just want to know what the best way is to run this sub, at 2ohm or 4ohm?
Wiring it up is no issue, it's just with the power handling I don't know which would sound/perform better. Obviously with the amp running at 4ohm it will be putting out 300rms which is perfectly matched to the subwoofer rating which is also rated at 300rms but I have heard it's better to have a more powerful amp running a less powerful subwoofer as it performs better?
Also heard that running the amp or powering the sub at a lower ohm gives better sound quality? I don't want to crank 500rms into it and blow it up if that's going to be the case if I run it at 2ohm..
Any help would be appreciated - I have included links to the full specs of the amp and sub
ALPINE MRP M500 MONOBLOCK
ALPINE SWS 1223D TYPE S SUB
Thanks in advance
https://www.sau.com.au/forums/topic/244785-2ohm-vs-4ohm/
4 Ohm.
It's then perfectly matched for the sub, and has the added bonus that it will not be 'straining' the amp as much (i.e. it should run cooler). Also, you're much less likely to blow the sub accidentally. Personally I like to have my amp about 10% more powerful than my sub, and then just make sure I'm not driving it to 100%. The last thing you want it amp clipping (distortion), as that will generally exceed the thermal and/or dynamic limits of the sub, and will therefore fry a sub dam quick!
https://www.sau.com.au/forums/topic/244785-2ohm-vs-4ohm/#findComment-4260678
I have decieded to run the amp at 2ohm as it will probably overload or run the risk of blowing if powering the sub at 4ohm
Thanks
Why do you say that? 2ohm is working the amp far harder than 4ohm... and so long as it's tuned right (i.e. no clipping - so not pushing the limits of the sub) it should go practically forever.
https://www.sau.com.au/forums/topic/244785-2ohm-vs-4ohm/#findComment-4260684
I looked at it in the way that the 2ohm puts out 500RMS but I will not be running anywhere near that to power the sub, probably half of that power to get adequate sound without distortion but when running the amp at 4ohm I will be running it almost to it's full potential for it to put out close to 300rms to get the sub going to its full potential
Wouldn't the amp be more loaded up running @ 2ohm 300rms than @ 4ohm 300rms?
Some other information I have just got;
Now to confuse you, If you want to run a single Type S 12"...
To run your amp with a 4Ω load: You will need SWS-1223D - dual 2Ω voice coils wired in series
To run your amp with a 2Ω load: You will need SWS-1243D - dual 4Ω voice coils wired in parallel
If you have already bought the Type S SWS-1223D, it can only be wired up as 1Ω or 4Ω, and since that amp specs are only 2Ω or 4Ω, you'll be stuck with 4Ω since the amp is not going to be 1Ω stable.
If you want 2Ω, you will need to buy the SWS-1243D Subwoofer, or another SWS-1223D and run two (but then you'll have 600w of sub for 500w of amp).
Looks like I might have to run it at 4ohm
https://www.sau.com.au/forums/topic/244785-2ohm-vs-4ohm/#findComment-4260760
Not really... In reality it'd be about the same... but the higher the resistance the less 'load' placed on the components of the amp (which most importantly results in less heat being generated).
Well, that's not 100% true.
Current (amps) = sqrt(power(watts)/resistance(ohms)
= sqrt(300/2)
= sqrt(150)
= 12.3A
= sqrt(300/4)
= sqrt(75)
= 8.66A
So as you can see, you're drawing LESS current to push the same power into higher resistance.
Now that's assuming equal efficiencies of the amplifier, which isn't actually valid, so the difference won't be that much, but it works to illustrate a point!
If you have already bought the Type S SWS-1223D, it can only be wired up as 1ohm or 4ohm, and since that amp specs are only 2ohm or 4ohm, you'll be stuck with 4 since its not going to be 1 ohm stable.
That's exactly right... the sub in question has dual 2ohm voice coils. So, if you wire them in parallel, you get:
1/R = 1/2 + 1/2
1/R = 1/1
R = 1ohm
Wiring them in series, you get:
R = 2 + 2
R = 4ohm
So that particular sub only supports 1ohm and 4ohm configurations.
Edited by Samon
https://www.sau.com.au/forums/topic/244785-2ohm-vs-4ohm/#findComment-4260799
ah awesome, thanks for clarifying Sam
Not so good with this stuff, too technical for me lol
I've got the jumpers that came with the subwoofer as well as a wiring manual to run it at 1ohm, 2ohm, 4ohm, 8ohm so I will just follow that and run it at 4ohm
Just out of curiosity, is there much noticeable difference from 2ohm to 4ohm in terms of sound quality?
https://www.sau.com.au/forums/topic/244785-2ohm-vs-4ohm/#findComment-4260804
No problems!
You can run it at 2ohm or 8ohm??? how???? it's only got two voice coils... to get 2 or 8 ohms you'd need two subs...
In theory, none. The only difference might be that at 2ohm you would not be edging towards the limits of the amp, and so you are at less a risk of clipping out (although more at risk of overdriving your sub!). Tuned properly to avoid any clipping/distortion it should not sound any different.
https://www.sau.com.au/forums/topic/244785-2ohm-vs-4ohm/#findComment-4260830
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
