Ok so basically im looking for some insight into my little problem.. that is, my Silhouette just wont run..
It all started a few months ago, i managed to slide into a curb an put a nice hole in my radiator [not my fault =P] and get a flat tire.. no biggy.. it still ran.. as it was started to move it.. but about an hour or so later [not really sure how long] it just wouldnt start.. so then the battery dies.. so we try an jump it an the leads got put on wrong, had a melted wire at the battery terminal and the ecu got fried.. so i replaced both of the obvious, and it would start, would struggle to hold it, then die... also ive noticed that the lights inside the ecu are on.. are they meant to be?
So i got the injectors professionally cleaned, and replaced one dud.. cleaned all the sparkies, and even tested another airflow meter.. still nothing.. and now a month after i last worked on it, i cant get it to fire at all...
I'm thinking its maybe an electrical problem..
But any help at all would be very much obliged...
https://www.sau.com.au/forums/topic/244802-help-it-just-wont-run/
