newbie question.
I saw a Eng No. of R33 start as RB25...., but I quite sure that r33 has a turbo and someont told me it is r33 GTST. I'm confused, I think GTST would be start as RB25DET...
By the way, I haven't chect the number on engine, I just read it from the rego which pasted under windscreen.
https://www.sau.com.au/forums/topic/24482-confused-by-eng-no/
the engine designation model is an RB25DET - that is what nissan calls it. The Engine Number is stamped in the block, near at the rear behind the turbo - it starts with the block type (in this case 'RB') and then a bunch of numbers and/or letters that mean pretty much bugger all to you and i. To nissan however, it should mean something :confused:
You won't find "RB25DET" stamped anywhere on the engine or firewall. You will find it on the build plate and/or compliance plate.
The engine number like Ronin09 said is stamped behind the turbo, and in your case should read something like "RB25 XXXXXXx".
Your chassis number is stamped on the firewall and will read something like "BCR33-XXXXXX" like rob77 said.
The VIN is the long, rectangular plate pot-riveted onto the firewall.
For example(my car is an R32 GTS-4):
My engine number is "RB20 XXXXXXA"
My chassis number is "HNR32-XXXXXX"
My VIN is "6T91XXXXXXXXXXXXX"
You derive "RB25DET" by what the car is equiped with.
"RB": RB=block type/series, "25" 2.5 litre engine capacity, D=Double overhead cam (DOHC), E=Electronic fuel injection (EFI), and T=Turbo/Turbocharged.
Hope this helps.
cobo
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
