I have a premium coupe with Bose sound system as usual. Lately when going around corners the left speakers are dropping out. Now over some bumps the sound goes in and out. At first I thought it was just a loose speaker wire in the left hand door, but I have since realised the Left rear side speaker is doing the same thing, which I am guessing may have something to do with where the speaker wire plugs into the back of the stereo itself.
Just wondering if anyone has any suggestions before I start pulling the dashboard to bits?
https://www.sau.com.au/forums/topic/244823-bose-speaker-problem/
two things there. the lock is a different probelm and a BITCH to change. about $300 for a new one ex japan.
the audio issue. look at the amplifer in the rear left corner of the boot. pull that out and down then look for dry joints. the radio does this as well but I have yet to see it.
Thanks for that Chris. I'll have a look at that. Now what is a "dry" joint?
If my year 10 electronics serves me correctly I believe it is something to do with fouled solder/contact points on the circuit board, either from wear and tear or from the factory
or components that have worked loose due to vibration. considering how that amplifier is mounted I would point the problem there.
Dry joint, you need to re-heat the solder up and make sure it has continuity all the way through the joint.
If you are a bit unsure any good electrical component repair shop could do it fairly easily... or Chris I would think.
no probs. I'm between cars now (have another sedan due inthe morn) I'll take one of these amps out and take a few snaps of it for you.
if you do head down to see me - ring first.I'm not always here.
Yeah thanks.
I had a look at it this arvo, sure is a lot of wires going into the amp. Pulled out the plugs and had a look around, couldn't see anything obvious, but as a result of pulling it apart, I think the speakers down the left hand side are now sounding very ordinary (very little grunt) compared to the right hand side.
If I may make a suggestion before you rip the car apart looking for amps and shit, test something first.
When you're getting the problem while listening to a CD, flick over to the radio and see if it happens there (or any other audio source aside from the CD player if you have one). I get the feeling the problem is isolated to the CD player.
The 350Z Bose stereos have a known issue (with TSB I'm pretty sure, although I don't have it to hand) where the speakers intermittently drop out while playing CDs. It doesn't happen with the tape deck or tuner (or aux input for those cagey enough to figure out there was one), and it feels like a loose connection since hard accelerating/braking can start/stop the problem. US guys have complained about it, as have a few Australians I know. Since the Z and V share so many components, it could be a common theme.
Nissan Aus didn't even bother fixing it when 2 of my mates had the issue with their Z's. The head unit was replaced. Mine did it just after warranty expired. At first it was the passenger side (both front and rear). Then the driver's side occasionally. Then both. Then back to passenger side. I ended up using a FM tuner or tape to line-in converter with my iPod. I replaced it with a double DIN, and kept the amps and speakers stock, and haven't had issues since.
Edited by scathing
I think that's the exact reason!! When I play CD's like I mentioned above, the left side starts to cut out. Hard braking/accelerating does help the problem. I have tried to switch between the CD player and Radio and have found that it does not happen when I have the radio on. Hopefully installing a Dvd player with mp3 will work? Since it will be using the Aux setting? How else would you fix it ?
I dropkicked the Bose CD player into the bin, and installed an Alpine IVA-W202E.
Using the aux input should be OK, as the other two sources on my head unit (radio, tape) worked fine and I used interfaces to get my iPod to work.
Could this mean a 'Class Action' against B%SE?
Could B%SE prefer to compensate you all if you advertised in the media that...
a whole raft of people (SAUers undercover) were going to be present at a particular destination (after halfway thru a SAU Cruise) to...
SHOOT DEFECTIVE B%SE CAR AUDIO EQUIPMENT WITH A SHOTGUN !!!!!!!!
Wouldn't they prefer to pay you guys out than to LET THE SHOTGUN GO OFF!!!!! AND THE PUBLICITY THAT WOULD GET!!!!!
    • Don't take it as a guarantee. It's all a game of statistics. And on top of that, smooth over a thick layer of "quality of spanner spinning" as a further Gaussian curve of probability of failure. You play games at anything above ~400 HP, and you're using up margins in terms of engineering and luck.
    • Aye, everything is being touched and all the parts that are responsible for the oiling issues are also fixed. (Crank collar, billet prp oil pump, head return to sump, yada yada yada)  Everything used is of reputable brands like greddy, prp etc. My tuner did mention we’d keep the torque on the “lower” side.   glad to read that my engine won’t blow up on me lmao
    • It's a fuel pump. EFI, high pressure, but specs otherwise unknown. A bodge job.
    • 800 engine horsies is fine. Will need all the obvious upgrades. Rods, pistons, oil pump, big sump, sump breathing mods. Build for revs because revs are power with less stress on the bottom end compared to boost. Keep the torque down in the midrange, either by limiting boost or timing.
    • Hiya guys,    i’m currently in the process of getting my rb26 built. everything is being replaced with better/upgraded parts or oem when that’s good enough (which isn’t alot lol). someone earlier mentioned to me that i’ll be screwed cause the iron block can’t take 800hp (to the engine, not wheels) which is what it’s being built for.  what do you guys think about this, am I cooked or na? The guy building the engine will also do the mapping as he is “the guru of old nissan engines” here in Belgium. I know the mapping makes a huge deal so i’m not concerned about that.    I honestly he’s talking shit cause he’s that kinda guy but a second opinion never hurt anyone! cheers in advance! 🫶🏻
