I have a premium coupe with Bose sound system as usual. Lately when going around corners the left speakers are dropping out. Now over some bumps the sound goes in and out. At first I thought it was just a loose speaker wire in the left hand door, but I have since realised the Left rear side speaker is doing the same thing, which I am guessing may have something to do with where the speaker wire plugs into the back of the stereo itself.
Just wondering if anyone has any suggestions before I start pulling the dashboard to bits?
https://www.sau.com.au/forums/topic/244823-bose-speaker-problem/
two things there. the lock is a different probelm and a BITCH to change. about $300 for a new one ex japan.
the audio issue. look at the amplifer in the rear left corner of the boot. pull that out and down then look for dry joints. the radio does this as well but I have yet to see it.
Thanks for that Chris. I'll have a look at that. Now what is a "dry" joint?
If my year 10 electronics serves me correctly I believe it is something to do with fouled solder/contact points on the circuit board, either from wear and tear or from the factory
or components that have worked loose due to vibration. considering how that amplifier is mounted I would point the problem there.
Dry joint, you need to re-heat the solder up and make sure it has continuity all the way through the joint.
If you are a bit unsure any good electrical component repair shop could do it fairly easily... or Chris I would think.
no probs. I'm between cars now (have another sedan due inthe morn) I'll take one of these amps out and take a few snaps of it for you.
if you do head down to see me - ring first.I'm not always here.
Yeah thanks.
I had a look at it this arvo, sure is a lot of wires going into the amp. Pulled out the plugs and had a look around, couldn't see anything obvious, but as a result of pulling it apart, I think the speakers down the left hand side are now sounding very ordinary (very little grunt) compared to the right hand side.
If I may make a suggestion before you rip the car apart looking for amps and shit, test something first.
When you're getting the problem while listening to a CD, flick over to the radio and see if it happens there (or any other audio source aside from the CD player if you have one). I get the feeling the problem is isolated to the CD player.
The 350Z Bose stereos have a known issue (with TSB I'm pretty sure, although I don't have it to hand) where the speakers intermittently drop out while playing CDs. It doesn't happen with the tape deck or tuner (or aux input for those cagey enough to figure out there was one), and it feels like a loose connection since hard accelerating/braking can start/stop the problem. US guys have complained about it, as have a few Australians I know. Since the Z and V share so many components, it could be a common theme.
Nissan Aus didn't even bother fixing it when 2 of my mates had the issue with their Z's. The head unit was replaced. Mine did it just after warranty expired. At first it was the passenger side (both front and rear). Then the driver's side occasionally. Then both. Then back to passenger side. I ended up using a FM tuner or tape to line-in converter with my iPod. I replaced it with a double DIN, and kept the amps and speakers stock, and haven't had issues since.
Edited by scathing
I think that's the exact reason!! When I play CD's like I mentioned above, the left side starts to cut out. Hard braking/accelerating does help the problem. I have tried to switch between the CD player and Radio and have found that it does not happen when I have the radio on. Hopefully installing a Dvd player with mp3 will work? Since it will be using the Aux setting? How else would you fix it ?
I dropkicked the Bose CD player into the bin, and installed an Alpine IVA-W202E.
Using the aux input should be OK, as the other two sources on my head unit (radio, tape) worked fine and I used interfaces to get my iPod to work.
Could this mean a 'Class Action' against B%SE?
Could B%SE prefer to compensate you all if you advertised in the media that...
a whole raft of people (SAUers undercover) were going to be present at a particular destination (after halfway thru a SAU Cruise) to...
SHOOT DEFECTIVE B%SE CAR AUDIO EQUIPMENT WITH A SHOTGUN !!!!!!!!
Wouldn't they prefer to pay you guys out than to LET THE SHOTGUN GO OFF!!!!! AND THE PUBLICITY THAT WOULD GET!!!!!
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
