After some different sensors to add into the logger but looking for somewhere to buy the sensors from, ideally somewhere that charges a fair price?
Can anyone offer some suggestions (australian?) that they have purchased from before and were happy, looking at the Bosch site i could follow up with a dealer but when i tried a few dealers i got frustrated trying to get prices and part numbers right with them.
Ideally somewhere that actually knows what they are talking about would be great.....
Matt
https://www.sau.com.au/forums/topic/244857-bosch-delco-or-vdo-sensors/
Ive always found ACA to be easy to deal with and providing you have done the leg work, found the part numbers and know what you want they are very helpful.
Ive also found in the past if I call them with a Bosch number they oftern have the same part in their own brand for cheaper.
Automotive Components Australia
(02) 9907 1861
They have their own range of products as well as the generic Bosch etc.
They stock just about everything you could ever need sensor wise and are very helpful.
There is another company whos name I cant remember atm but ill get their contact details for you as well tomorrow.
Edited by Risking
people like Auto One and other places are agents for ACA, so should have catalouges etc. ive got one at work. if you let me know what your after i should be able to price it and find avalabillity.
thanks, will print out the bosch catalogue with the part numbers and give them a buzz.
ACA is no good, they only have the OEM ones and nothing that i can use on loggers. Tired to use the Bosch part numbers and the guys told me they only do the OEM ones and that is it. I could probally use some OEM type one as long as i could get all the specs on their resistance etc to plug into the loggers data so it knows what it means but might be more effort then it is worth.
Brad,
What was the name of the other place?
Matt
.....so ended up getting sensors from Meridian Motorsports in Melbourne.
1 Bosch Water Temp
3 Bosch Oil Temp
2 Delco Air Temp
1 VDO Oil Pressure
All with conectors, the Water and Oil were under $17 each, Air sensor was a little bit more and the Pressure was $99. Have to also get made up a remote mount to put the pressure sensor onto the firewall to insulate against some of the vibration.
matt
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
