After some different sensors to add into the logger but looking for somewhere to buy the sensors from, ideally somewhere that charges a fair price?
Can anyone offer some suggestions (australian?) that they have purchased from before and were happy, looking at the Bosch site i could follow up with a dealer but when i tried a few dealers i got frustrated trying to get prices and part numbers right with them.
Ideally somewhere that actually knows what they are talking about would be great.....
Matt
https://www.sau.com.au/forums/topic/244857-bosch-delco-or-vdo-sensors/
Ive always found ACA to be easy to deal with and providing you have done the leg work, found the part numbers and know what you want they are very helpful.
Ive also found in the past if I call them with a Bosch number they oftern have the same part in their own brand for cheaper.
Automotive Components Australia
(02) 9907 1861
They have their own range of products as well as the generic Bosch etc.
They stock just about everything you could ever need sensor wise and are very helpful.
There is another company whos name I cant remember atm but ill get their contact details for you as well tomorrow.
Edited by Risking
people like Auto One and other places are agents for ACA, so should have catalouges etc. ive got one at work. if you let me know what your after i should be able to price it and find avalabillity.
thanks, will print out the bosch catalogue with the part numbers and give them a buzz.
ACA is no good, they only have the OEM ones and nothing that i can use on loggers. Tired to use the Bosch part numbers and the guys told me they only do the OEM ones and that is it. I could probally use some OEM type one as long as i could get all the specs on their resistance etc to plug into the loggers data so it knows what it means but might be more effort then it is worth.
Brad,
What was the name of the other place?
Matt
.....so ended up getting sensors from Meridian Motorsports in Melbourne.
1 Bosch Water Temp
3 Bosch Oil Temp
2 Delco Air Temp
1 VDO Oil Pressure
All with conectors, the Water and Oil were under $17 each, Air sensor was a little bit more and the Pressure was $99. Have to also get made up a remote mount to put the pressure sensor onto the firewall to insulate against some of the vibration.
matt
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
    • The ones in brackets are the first stages of tightening. I usually aim for the middle of the range. They give a range because it's actually not that critical to hit exactly the right bolt tension. Enough is enough, and too much is too much, and the range given is inside that range. Half of the bolts in the suspension are problematic for putting a torque wrench on anyway, so just get done up to mechanic tight  and spanner checked a week later.
