V Spec Hits The 'ring
agg25
 Share
Just found this while on topgears website, hopefully not old news. There's a video on their website too, sounds nice and throaty.
from - http://www.topgear.com/uk/car-news/2008-11-13-nissan-gtr
GT-R’der
Nissan has confirmed that a Spec-V GT-R is on the way: a more powerful, lighter version of its supercar-eating Godzilla. It sounds mental.
Rumoured to arrive at the Nismo Festival being held at the Fuji Speedway at the end of this month, the Spec-V could put out as much as 580bhp from its twin-turbo 3.8-litre V6 – a full 100bhp up on the already-brutally-quick GT-R.
Those power gains will be achieved through increased turbo boost and a revised ECU and exhaust system, but the upgrades won’t stop there. Plenty of carbon fibre will ensure that the Spec-V will be significantly lighter than the stock GT-R… which could mean we’re looking at a car that’ll hit 60mph in under three seconds. Jeez.
It won’t come cheap, though. The Spec-V is expected to weigh in at around $150,000 in Japan, with European prices as much as double those of the normal GT-R - £100,000 or so here in the UK, then.
If you need convincing that it’ll be worth it, take a look at the video below featuring a few spy shots of a Spec-V prototype taking to the ‘Ring. If the normal GT-R can lap the Nordschliefe in 7m29, how quick is the Spec-V going to be?
It’s not going to impress Porsche, is it?
Edited by agg25
A bit of nice spy-footage.
I'd have to believe though, that Porsche and others would have anticipated that Nissan would be sending the standard GT-R to 'jenny craig' and putting in an upgraded ECU like what's in the Haltech version now!
The standard R35 GT-R was just the appetiser.
I hope they don't upgrade to Haltech's Version I ECU...
Props to H'tech for having the nuts to push the envelope, tho'!
Gosh. Under 3 seconds!?
There only are a hndfull of stock cars in the world that are that quick. None of them anywhere near this price.
Awesome just got better!
Would definitely would take it with a grain of salt! money probably better spent tuning a stock base model GTR (warranty issues aside - if you even care!)
the first scene of the gtr on the streets is the same place where the spy shots of the 370Z were taken...... anyone know where that is????
Yeah well I hear Kimmi Raikonen has asked Ferrari to put a 6MT in his F1 car next year because it's much better than his flappy paddles. And since the Spec V is going to be pretty much a dedicated racer I expect they'll follow suit.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
