Just found this while on topgears website, hopefully not old news. There's a video on their website too, sounds nice and throaty.
from - http://www.topgear.com/uk/car-news/2008-11-13-nissan-gtr
GT-R’der
Nissan has confirmed that a Spec-V GT-R is on the way: a more powerful, lighter version of its supercar-eating Godzilla. It sounds mental.
Rumoured to arrive at the Nismo Festival being held at the Fuji Speedway at the end of this month, the Spec-V could put out as much as 580bhp from its twin-turbo 3.8-litre V6 – a full 100bhp up on the already-brutally-quick GT-R.
Those power gains will be achieved through increased turbo boost and a revised ECU and exhaust system, but the upgrades won’t stop there. Plenty of carbon fibre will ensure that the Spec-V will be significantly lighter than the stock GT-R… which could mean we’re looking at a car that’ll hit 60mph in under three seconds. Jeez.
It won’t come cheap, though. The Spec-V is expected to weigh in at around $150,000 in Japan, with European prices as much as double those of the normal GT-R - £100,000 or so here in the UK, then.
If you need convincing that it’ll be worth it, take a look at the video below featuring a few spy shots of a Spec-V prototype taking to the ‘Ring. If the normal GT-R can lap the Nordschliefe in 7m29, how quick is the Spec-V going to be?
It’s not going to impress Porsche, is it?
Edited by agg25
https://www.sau.com.au/forums/topic/244868-v-spec-hits-the-ring/
A bit of nice spy-footage.
I'd have to believe though, that Porsche and others would have anticipated that Nissan would be sending the standard GT-R to 'jenny craig' and putting in an upgraded ECU like what's in the Haltech version now!
The standard R35 GT-R was just the appetiser.
I hope they don't upgrade to Haltech's Version I ECU...
Props to H'tech for having the nuts to push the envelope, tho'!
Gosh. Under 3 seconds!?
There only are a hndfull of stock cars in the world that are that quick. None of them anywhere near this price.
Awesome just got better!
Would definitely would take it with a grain of salt! money probably better spent tuning a stock base model GTR (warranty issues aside - if you even care!)
Yeah well I hear Kimmi Raikonen has asked Ferrari to put a 6MT in his F1 car next year because it's much better than his flappy paddles. And since the Spec V is going to be pretty much a dedicated racer I expect they'll follow suit.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
