Originally posted by Duncan
easy, I've got some you can borrow, also have blue, white, yellow and red (goes fastest) ;)  You'll have to come out on 2 October now (just like Franks is :/ )
:D
you're going to need alot more bait than that duncan :)
that said, im very close to coming next tuesday down to wakefield. i have a day-in-leui oweing and if i dont take it soon, they'll forget about it....hrmmmmm
yes its a GTT.
thing popping out the side looks like an intake pipe???
have uploaded under the bonnet picture..! (see first post)
from http://www.mzou.com/column/index.cgi?no=8
interesting to see a low mounted T88.....
"...RB25 reforming 28
2002/10/27 (Sun) 16:25
It became the new engine.
This time RB25 reforming 28, it is the T88 turbine.
Usually, the turbine being to be many a thing which is attached above ƒ}ƒj it does, but
This time it is attached underneath ƒ}ƒj.
Any weight things probably will put out consideration to with if possible low position, is.
With, with the photograph the turbine is not visible by the fact that you say, is.
As for the part which modifies together even in the next time.
Truth the result of the apex cup with Tsukuba together
Being to intend probably to write, it does, but
In the rain, there is no extent courage which can be stepped on in new specification. . .
The opportunity it goes to Tsukuba again...."
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
