Hey all i got bored today and PURELY out of boredom i decided to block of my BOV whilst doing this i went for a drive and heard it and then i got home, put it into neutral and released my foot off the brake and the revs where fluctuating from 600-900RPM, just wanting to know why?
Thanks guys!
And im not a hektik muzza etc i just wanted to learn more about my car on a boring day
https://www.sau.com.au/forums/topic/244872-flucuating-idle/
because the ecu in the car expects the air to be plumbed back into the system, but now that air has dissapeared and the car is freaking out :)
You put an atmo bov in the car, car stalls. Nothing to worry about, just remove the block plate and leave it as is. Problem solved.
https://www.sau.com.au/forums/topic/244872-flucuating-idle/#findComment-4262079
Ok i removed the block plate and the problem is still there come to think of it, it was there before i blocked it...
Is it becuase i just installed a pod filter or?
Because the cars revs are going up and down a couple of hundred RPM and when the car is idling it sounds a bit rough!
I just put a 3A pod in 2 days ago could the be the cause
https://www.sau.com.au/forums/topic/244872-flucuating-idle/#findComment-4264449
Nah the o2 sensor would cause your fuel economy to be shocking, idle variance CAN happen but it's rare.
If the problem wasn't present before you put the pod on then its the pod filter.
The reason the idle will fluctuate could be that a) the pod isn't on properly b) you didn't put the afm plug back in tightly c) the afm could have picked some crud up and you may need to clean it. Take the pod off and get some brake cleaner into the afm to clean it. Make sure you clamp up the afm tightly and secure the pod so it doesn't move. Hopefully it's all good.
https://www.sau.com.au/forums/topic/244872-flucuating-idle/#findComment-4267295
AAC Valve? When I first got my car the idle was hunting around a bit and sometimes stalled when pulling up to lights etc. Searched around here and someone suggested cleaning the AAC valve, after I cleaned it problem gone. I think theres a guide in the DIY section if you're not sure how to do it but could be worth a try.
https://www.sau.com.au/forums/topic/244872-flucuating-idle/#findComment-4267962
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
