Hey
Just bought myself a very comfy recaro however as im a super short ass and cant reach the clutch unless its nearly all the way to the front I have found after 3 hours I have already broken 1 nail trying to undo the seat belt from the damn buckle as it sits wayyyy to low for a girl to reach under and press, and as im having to press with my nail not my finger 1 nail has suffered massive carnage and well although I like to be comfy my nails come in a set of 10 not 9 or even 8. haha
Just wondering what buckles ppl are using or if im the only spazz to encounter this issue? :)
https://www.sau.com.au/forums/topic/244880-recaro-1-danielles-nails-1/
Terry yes, sad but true although out of the 3 hours due to the pain in the ass spot of the buckle I reduced usage of it to twice, that and I was driving a distance so stop 1 servo, stop 2 destination.....with broken nail, sore thumb and the set of 10 no longer.
So...really after only 2 uses..the farker is winning!
I'm sure given time, more could be destroyed in my quest for a comfy ass, but I'm currently seeking an easier option as the 2.5 month growth period to re-join the group is a looooong time ;)
in all seriousness tho..god forbid if I have to get out of this seat belt n a hurry, cause well really I just cant :)
Dont know wether its still an option but years ago my short arse aunt had a similar prob. They fixed it with "pedal blocks" Basically just pedal extensions to enable her to reach the pedal without her chest being caved in on the steering wheel.
Fine line thank you for the thought, this would be a fantastic idea if I had clearance issues with the steering wheel. However although Im a short ass the steering wheel and my proximity are all ok, its only this belt buckle location that causing the issues for the nails.
That's just not good enough Danielle if you get car-jacked! The jerk will just lose patience with you!
Then you ask him what his mother's name is?
And if he says, "Why? My Mom's name is Gabrielle WTF"
Then you say, "Well you can't shoot me then, 'cause my name's Gabrielle too!"
You can talk your way out of anything can't you? :)
...except for a family of spiders of course
Tez
You can talk your way out of anything can't you? ;)
Tez
quite possibly on occasions...oh oh ..I mean NO, never :)
dori32 after discussions with my ass the comfort factor prevails and swapping is simply not an option.
Terry sadly I'm not into fake items on my person and my remaining real nails would object to such.
Crisis averted.....
I have established the fault lies not within nails too long, but within the buckle type used. Previous to now my ass liked the 32 gtr seat I was using, but after upgrading to the recaro the gtr buckle is deemed useless by the nails.
id consider myself a short ass too, but more cause i like my seating position high and close and not laid back. I have problems getting out of my gtr seats cause its so close to the steering wheel i sometimes roll out of the door in a fetal position. i have now reverted to kicking the seat back everytime i get out...one more thing to think about but its working so far.
I have no issues with the seatbelt though, maybe cause im using the compliance set for the gtst that is quite longer than the stocker gtr jap ones. on a note my compliance seatbelt buckles were too big to clip into the gtr jap ones so best to check if they can clip in before swapping anything.
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
