hey,
i have a brand new electric shaver..
i got it as a gift but i already had one!
these are the top of the line all in one cleaning unit...
after $250..
these retail in shops for $400...
please om or email @ [email protected]
specs..
Braun 360 Complete 8995 Self Cleaning System Shaver
The 360 Complete is Braun's latest top of the range
Evolution from the previous Activator range
Power Comb lifts hairs that lie flat to avoid missed hairs
New precision blades cuts hair close in a single stroke for closeness and comfort
Smart Foil uses a unique hole pattern to capture hair at different angles
Active head uses micro oscillations to enhance comfort and smoother gliding
Contour hugging head automatically adjusts with every facial contour
Clean and Renew system provides total daily shaver maintenace
Cleans the shaver head in alcohol for optimal hygiene and less irritation on the skin
Selects the best program based on how much cleaning your shaver needs
Cleaning formula also lubricates the blades for optimal cutting performance
Totally dries the shaver head at the end of the cleaning cycle
Shaver battery is automatically charged while seated in clean and charge system
LCD display provides information on battery capacity and cleaning status
Mains and Rechargeable from auto 110-240V for worldwide use
1 hour charge for upto 50 minutes shaving time
Automatic battery care using Braun SmartLogic charging system
Includes 1 cleaning refill (30 cycles), hard travel case and cleaning brush
https://www.sau.com.au/forums/topic/244896-brand-new-braun-8995/
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
