With much sadness the 4 Door will be put up for sale to make way for another GTR. This car was originally built by Martin Donnon at Willall Racing as part of "Project 11's" featured in 11 issue's of zoom magazine. Funly enough they never acheived a 11 second quarter. I did however =) 11.8 at WSID. The car setup works extremmely well. It runs a rare 5 speed Auto Nissan trans which also has a lockup high stall which gives 6 ratios! As you can imaging this makes the car very responsive at any rpm and also give suprisingly good fuel economy. During the original Build the transmission was fitted with a modified value body and kevlar clutch discs by Mike at MV automatics here in Adelaide. It was a very nice setup ,but now is better still. I've had the trans fitted with high performance valves and new kevlar discs during an overhaul earlier in the year so the shifts are now instant. The 3500rpm stall ensures lag free launches and multiples the torque to the extent you can pretty much fry the tyres at will at most speeds. When cruising however the lockup kicks in and she cruises just like the factory wanted...it really is an absolute pleasure to drive. The motor was stock and was rebuilt with new bearings, rings, 33 crank and turbo's. Standard bore 86mm CP forged pistons have been fitted to ensure a very reliable package. The car is also fitted with a full GTR rear cradle, (diff,etc), GTR front support for the R33 GTR front bumper and r32 GTR brakes all round.
Other upgrades are as follows:
R33 GTR front seats
Triple gauge dash cluster (white nissan)
Series 2 tail lights and center garnish
Full hard pipe kit (turbo inlets, turbo outlets, smooth transition twin turbo merge pipe)
Apexi filters
R34 AFM's x2
Apexi PFC
Apexi N1 Dual and std exhaust
boost set at a lazy 14psi max
Momo Evo Millenium style steering wheel
HSD damper and height adjustable coilovers
18" ROH 3 piece Strada wheels x4 + R34 std wheels x4
I haven't put the car on the dyno since I got it, however the tune has been adjusted each time the engine has been modified. I have many different tunes and data log files to go with the car. The current summer tune was comlpeted in the last month, runs 12.6:1 AFR and no knock what so ever.
The car has had most of the performance upgrades completed after my run at WSID and is now considerably faster. I won't give you a estimate of power, but I'm sure you can work it out from the time it has run
The car is currenlty registered and cleared through Regency for the engine change(papers included) so no need to worry about getting a canary.
The car will be ready for sale in the next few weeks. I originally purchased this car at a steel for $15,000 a year ago. After the additional mods and adding up how much I could part the car out for: I will be looking for $15,000.
Contact:
Matt
0413023669
or
Troy
0413307661
ps. the car will be at Mallala on Nov 20.
Edited by BoostdR
just wondering how good is the fuel economy on this?
Yeah it'd be fine as soon as you went into boost range. Then you could watch you fuel gague bungee jump. lol
  • 3 months later...
The car is in storage and hasn't been driven since my Brother-in-law got his GTR. He has just bought a house so if you through him offers you may get a real bargin. It does need some attention
-real bumper is burnt from the N1 dual exhaust (new silver bumper supplied, just fit)
-A wire from one AFM to the PFC is intermittent, just needs the break to be found
-two of the ROH rims have been dented and require re-rolling.
-DVD/SAT NAV has been removed but will be supplied
The engine is extremmely fresh and very clean any test welcome(leak down, compression, turbo play, headgasket, etc)
Get in quick
in terms of fuel economy, for those interested. im pretty sure this car was used for an article that involved tuning specifically for economy, and they got it from mid 14's down into the 11's (litres per 100km).
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
    • So my car is finally back from paint! This took an absolutely insane amount of work and should get it's own build thread - but I didn't build it. It was completed by Troy @ https://scalekustoms.com.au/ I originally bought the AOSHIMA URAS Type R kit while I was in Japan, it's supposed to look like this when assembled: Now, I thought that was cool enough until I opened the box with Dismay, as there's no way I could possibly have completed it. The thing is 1/24 and has details down to the steering wheel horn button, which is a 2mm diameter sticker. I originally wondered if someone could make it at all, as is - But then things got a little carried away. It's worth noting that the model does not have an openable bonne, let alone engine bay, OR an openable boot. - Troy has worked wonders with 3D printer and presumably better eyes than I will ever have. My photos suck, so I will post up some of his in-progress ones he sent to me during the way. Unsuprisingly, he is very detailed. A lot of these are out of order. But he: 1) Made a LS engine and an engine bay appear out of thin air 2) Made the bonnet removable 3) Printed the rims I will buy in the future (or any rim you want) 4) Printed and added the wing that is going on 5) Tinted my back windows as this is what my car has IRL (privacy glass) 6) Added a licence plate. 7) Somehow did the interior 8) 3D Printed my actual seats 9) Made the exhaust under the car connect even though this is likely invisible. 10) Created a boot with my fking battery box, power steering reservoir, subwoofer and toolboxes back there. To say it's insane is an understatement. And I f**ked it all up because when I was re-mounting the wing (it broke in transit) I spilled glue everywhere and ripped paint up and Gregged the rear half of the car. Which about makes sense. Also, this arrived on the same day. Quite the change from: I spent 16 hours per day over the next 3 days pre-christmas putting the interior back together, mounting lip, fixing various bodykit problems with window mouldings, etc. and servicing, rebuilding my 370z brakes to go on the car 'soon', messing with heights to check clearances for new wheels, etc. I also had a foray into mounting wiper-mounted washer jets which was an absolute disaster. The bodyshop has welded (and painted) over the stock jet locations for reasons unknown to everybody (i.e they forgot) I also wanted to wire in the oil pressure sensor on Christmas Eve which was a BAD IDEA. You do not know terror like pulling your ECU apart, pinning in half-fitting pins that aren't the right ones, but trying anyway because it's Christmas eve, putting your ECU back together and having a no-start condition with a fuel pump not priming. Then you undo all your work and the fuel pump still doesn't prime. So after all that terror and horror and pain and tedious disassembly, the issue was the relay in the boot which seems to have died/stuck when I was turning the car off and on about 700 times testing shitty washer jets. I also re-wired the fuel pump power plug which fell apart in my hands. I am very happy I had 3 extra pre-made ones from a few posts/last Christmas's breakdown. https://bluewireautomotive.com/products/10-x-pcm-ecm-ecu-terminals I have put an order for these in, so I can actually add the pins to the ECU properly. The commodore ECU does not have the pins for Oil Pressure via ODB2. However the ECU can support it if you create the pins and wire them in. So for round two, and somehow attempting to route that into the engine bay through my impossible engine bay grommet is a fight for another day. It's 40C in Melbourne tomorrow, I am half tempted to drive the car with the aircon on to deliver presents to my partner's family and see if it helps with the overheating-on-40C-days-in-traffic-with-aircon-on-only issue that the vents were intended to solve. Do I feel lucky?
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
    • You 100% could do that, would save money on a gym membership lol. But yeah, getting a cordless orbital sander will feel priceless coming from doing it manually.  Good luck with it mate
