Hi,
Yeah all the cars we buy ourselfs with our own money.
We try to keep 25-40 cars in stock at all times.
I will buy cars and import them wether they are sold or not. This puts a bit more pressure on me to make sure the cars are of good quality as my money is on the line.
I dont use dealers in Japan, I source straight from the auction floor, my business partner is my school friend Luke from NZ, he does most of the buying and he is at the Auto Auctions daily. We have all our car JEVIC inspected to ensure that all Kms on the cars are legit, check out the following link: http://www.jevic.co.jp/jevic_english/inspe...ces/index4.html the cars come with the paperwork to back this up.
I have a sold alot of cars in Australia to dealers and public buyers over the last 2 years, most come through the Trading Post and now the new web-site www.ozcarimports.com.
If you want any buyers numbers I am happy to provide them, but I always tell people to go check out some of the stock I have in Australia, drive it and theny ou can make up your own mind.
Any questions fire away.
Oz
Edited by OzCarImports
Hi guys , I've just bought a R34 4 door through Steve and he seems to be good bloke. They have been very helpful with a few things that happened to the car. Very easy to deal with, with all emails sent were replyed almost straight away.
Yep Oz Car Imports Highly Recommended :-)
Gday Steve
Thanks for the positive feedback guys.
I'll buy you a beer when I am back in Adelaide in a couple of weeks, maybe I shoud do a SA Skylines Ozcarimports.com shout some where??
Anyone interested?
Anyone interested?
hmmm now were talking free beer....
consider the legnum sold steve.
boot full of beer sounds awsome. hence buying a wagon....fit more in.
heres a pic of the aftermath of surgery.
Dam roller door at home bit me.
long story but lets just say i was wrestling with a rachet to tension the spring in the centre of the door
and the rachet won!
im dynoing the 33 in the morning then i will head to work for a few hours,
but i want to try and get out to see the legnum by about 3:30
and the rachet won!
Mate your lucky you didnt loose the lot!
I let the guys know that you going to look at the legnum
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
