ok coil packs are finally on there way, i bit the bullet and conned my parentals into buying them for me.
retracted - it is a wgnc34 thus rs4s :) yay for me (just out of curiosity, is there a way to tell what sort of stagea mine is?? what are the diffrences between rs4/rs4s etc..)
Edited by lilcrash
  • Replies 61
Posted Images
thats why i thought it was possibly r+r, and what i originally thought was a miss feels more like its stuck at certain rpms and is struggling to rev harder. so im guessing this is the "wall" that its hitting as mentioned earlier. kinda feels like revlimiter but a quicker space between bursts, for eg. rev limiter is like this rev..............rev.............rev.............rev, but this is like rev...rev...rev...rev.
so yer. im lost
Hi
This rev...rev...rev...rev sounds very similer to what i had a while back. It would hit at about 4000 rpm it turned out to be the fuel pump. One sard fuel pump and a fuel presure regulator an all is well againe. I would still go with the new coil packs as these will be a good investment if you intend to up the doost in the future.
cheers
phil
oh phil, now you have really confused things, he is sure to get the Corolla now :P
So in summary, 5 for coils, 4 for R&R and 1 for fuel pump.
I don't know if it is coils? how can you diagnose symptoms without testing? All anybody can offer is speculation, now that you have bought new coils I really hope it doe's solve your problem, cause if you were considering an insurance job before this might put you over the edge. Good luck with it. I gotta go insulate the wirring on my coil pack harness with silicone as nissan wrapped it with insulation tape (dodgey buggers)
Edited by rb30dett
phil, i think i may have to be against the fuel pump thing im sorry. its just that the problem goes away with the new spark plugs every time. but lately it only misses if i boot it after cruising for a while.
and chook if i was to get a toyota it wouldnt be a corolla. rather a jzx90 chaser.
i was kinda getting to the point where i wanted to make a deal with some one who is only upgrading coils for performance purposes. like borrow there coils for a day test or what ever.
thanks for the help everyone. after christmas i will know if the coils work.
well, fixes:
install a better fuel pump, such as a 040 Bosch, or gtr fuel pump
if not interested in outlaying cash then at the least wire the fuel pump to a direct battery feed, to get more voltage (13.8v)
a 2ndhand gtr fuel pump isnt expensive anyways.
build a air:fuel ratio kit from jaycar and install and tune, or find a 2nd hand safc II off ebay. search to minimise the cost.
use ngk BCPR6E copper .8mm vgruve plugs, under $20 for the 6. money definately not wasted, good for 20,000kms+ and 300rwkw
grab the selleys 401 hitemp industrial silicone sealant, and a corking gun from bunnings ($15 the lot), and go nuts on the coilpacks.
there will be plenty of sealant left for the toolbox so it isnt money wasted (lasts yrs).
with the new sparkies, the coilpacks sealed to stop wasted spark, and a better fuel pump with directwire battery feed to deliver max output, put the car on the dyno and tune the air:fuel ratio. adjust the timing slightly, and you'll gain power whilst providing better fuel economy, and it should hit the nail on the head as far as R&R or wasted spark goes.
my guess, $200 for the parts above all up plus a dynotune
money isnt the problem. my missus will kill me if i buy something i dont need is all.
sorry to be so late into this problem from my experience . I have found after weeks & weeks of sorting under boost & under standard boost i did have a break in the wiring loom for th coils . have been running up to the boost cut in an s2 for 25000 kms and have had no dramas . still run this boost now and looking at running more with a greddy profec b . good luck hope it works out for you soon .
well, fixes
if you want to have a mess like that good luck ,nice simplepost-36964-1227358939_thumb.jpg
post-36964-1227359032_thumb.jpgpost-36964-1227359327_thumb.jpgpost-8496-1123070395.jpgthen spray what colour you like ,there is few topic`s on coilpack`s & i have also posted on them ,but make sure you clean then well very well tape up connector`s & rubber cover, post-36964-1227359659_thumb.jpg i did mine 18 month`s ago & still sweet + i have found easy way to tell if it is coilpack`s ,PUT AC on FULL & if you get miss then you know what you are LOOKING for :) .cheer`s chuckie.
  • 1 month later...
the only issue i found is none of the bolt holes line up very well,( the 2 bottom ones are close enough that you can bolt them, but the top one and the one on the longer pipe is no where near the holes, i used the supplied zip ties to hold it for now until i can get new mounts put on) and it sits on a weird angle, i bent my mounts to lift it away from the road and level it.
that was exactly the same issue I have with my stealth cooler that the bolt holes don't match up (I got the top bolt hole to match but the bottom ones are slightly off)...I've just gotta make some time to make up a piece of steel that bolts to the two bottom mounts and then use one of the remaining L brackets I have to bolt it up to the middle (the center vertical bar where the horn and top mount of the cooler is)...and also fix my miss (new plugs) and investigate what sounds like an almighty air leak
tape has worked twice for me . one guy didnt even notice his car was missing . it was 100% the token miss . run clean get to 4.5k pop pop pop then pull hard rest of the way through . will buy split fires if my car ever needs coils . mine are mint atm
Greddy emanage Ultimate (im bias lol, but any after market ecu will do) chuck it on the dyno get it retuned for your mods.... presto problem solved. People waist alot of time and money and tempory fixes but something i have learned with my car is any mod you do to enhance performace (+- fuel, air, timing) while using the stock ECU will often cause you grief unless retuned properly.
I stress this is only my opinion and will probly have alot of people who disagree!
Edited by loymclure
post-36964-1227359032_thumb.jpgpost-36964-1227359327_thumb.jpgpost-8496-1123070395.jpgthen spray what colour you like ,there is few topic`s on coilpack`s & i have also posted on them ,but make sure you clean then well very well tape up connector`s & rubber cover, post-36964-1227359659_thumb.jpg i did mine 18 month`s ago & still sweet + i have found easy way to tell if it is coilpack`s ,PUT AC on FULL & if you get miss then you know what you are LOOKING for :D .cheer`s chuckie.
brilliant chuckie - thanks for that adaption of an idea :cheers: I'm gonna take a look around for that spray silicone.
yer just a quick update, ITS BACK . . . . . . . . . dun dun dun (evil music)
It's gonna be your coilpacks mate... I had exactly the same issue once i raised the boost to 10psi.. Car was missing badly around 4500rpm then would slowly clear up... changed the coil packs to spitfires and now pulls hard all the way through to redline..
ive had the miss since i bought the car(it was stuck on 3psi, the intercooler put it back to the stock 10psi) so boost isnt the problem, but yer im going to assume its coil packs. hopefully when i get my check from just cars il get some splitfires(even though i should replace me rims so i dont have to keep reinflating them), i should have just got my parents to get them like they were going to, i only told them to get the cooler because i had a huge boost leak.
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
